Results 1 to 10 of 19
Thread: Throttle Cracker and Follower
    Mar 2004
    Default Throttle Cracker and Follower
    Todays dumb question:
    The VE table tells the PCM how much air the engine is using at RPM and MAP and therefor how much fuel it it should add.
    The throttle cracker adds to that based RPM and Speed and the throttle cracker adds based on TPS (and multiplied by the RPM multiplier).
    So, are the throttle cracker and follower an additional airflow/fueling signal to the PCM that in effect would be same as adding to the VE if all conditions were static or do they do something different?
    I ask because I am running lean at like 7% to 10% throttle in the 1400 to 2400 rpm range and trying to figure out the best strategy to solve it. All other conditions - idle, higher RPM and throttle, deceleration, etc. are nearly perfect so I don't want to affect anything except the problem area.
    Thanks!
    2000 Camaro SS Convertible
    M6,
    LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Under the conditions you're describing, (assuming steady state operation at the throttle position and rpm you mention) throttle follower and cracker should be pretty well out of the picture. Under the idle folder, look at the follower and cracker descriptions and see if that makes sense. Sounds like you need to adjust your VE table or you're running into DFCO.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Jun 2005
    Throttle cracker and throttle follower do allow air into the engine via the IAC. However, it's post MAF air that's already metered. Therefore, fueling should have already been calculated (even if you're running SD). They are for driveability alone.
    If you're running lean, you need to add fuel via the VE or MAF tables (or if you're old school, the Injector Flow Rate table or Commanded Fueling in Open Loop Table).
    Oct 2006
    Listen to this guy he knows what he's talking about!!!!
    Oct 2006
    Quote Originally Posted by SSpdDmon
    Mar 2004
    Thanks for the replies gang, so looking at my log and tune, even though my VE table seems high alredy in that range I should add more to bring the fueling up?
    I would also appreciate it if you had a look to see if there is anything else I'm missing?
    M6,
    Jun 2005
    Doesn't look too high to me...
    Here's what my VE looks like with my setup.
    Wow!!!!! How do you get such a nice smooth table and keep fueling right? I'm figuring you're cammed with the hp in your sig. Here's mine and it still isn't dialed in.
    Jun 2005
    Quote Originally Posted by ViolatorTA
    That's just it. You can dial it in for the cell at a given rpm/kpa. But, once you stray from the center of that cell and the pcm starts interpolating the fueling is going to be off a little - usually up to 3~4% in some instances. I'm still tweaking mine a bit here and there. Once I'm done, I plan on increasing it 2% so that the variance is -2~2% instead of 0~4%.
    Mar 2004
    So as to compare, mine is in % and yours is in units kelvin, how do I change the units - it's not imperial versus metric......???
    M6,
  1. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  2. Explain throttle cracker and follower..again!
    Last Post: February 25th, 2009, 09:18 AM
  3. throttle follower/cracker
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: December 10th, 2008, 04:15 AM
  4. Throttle cracker/follower, Y bodies
    By edcmat-l1 in forum Gen III V8 Specific
    Last Post: October 5th, 2008, 09:16 PM
  5. throttle cracker and follower
    By jkg in forum General (Petrol, Gas, Ethanol)
    Last Post: November 6th, 2006, 05:41 AM
