Results 1 to 5 of 5
Thread: Need Help just installed my WB02
    May 2007
    Default Need Help just installed my WB02
    I have a NGK WB I got everything installed and it seems to be working fine except the Base efficiency PID has a X through it??? The AFR will show up fine and seems to be working though. Here is the text File I took out the D in "{CALC.AFRNGKDAD1.AFR}/{GM.AFR}" and it still did not work im stumped and I really want to start tuning!
    2001 SS Camaro M6
    Nov 2006
    did you select the external analog voltage pid?
    May 2007
    Yup this is drivin be crazy cause it is the only hold up.
    2001 SS Camaro M6
    May 2007
    Here are the pids.
    Here is the error I get under more information.
    Base Efficiency Numerator 1 - NGK {CALC.BENNGKAD1}
    Expression:
    factor = {CALC.AFRNGKDAD1.AFR}/{GM.AFR}
    is NOT valid because:
    Unknown parameter {CALC.AFRNGKDAD1.AFR}, at position 22.
    PID value cannot be determined because
    the following error would occur:
    Expression not valid: Unknown parameter {CALC.AFRNGKDAD1.AFR}, at position 22.
    2001 SS Camaro M6
    May 2007
    Yesssssss I fixed it!
    Changed {CALC.AFRNGKDAD1.AFR} to {CALC.AFRNGKPLXAD1.AFR}
    2001 SS Camaro M6
  1. possible problem with PLX WB02
    By jfclubby in forum Gen III V8 Specific
    Last Post: June 18th, 2008, 05:26 PM
  2. Has anyone tried this WB02 controller yet?
    By FreddyG in forum Gen III V8 Specific
    Last Post: January 5th, 2007, 12:08 PM
  3. WB02 Location Question
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2006, 01:20 PM
  4. Zeitronix WB02
    Last Post: December 10th, 2005, 10:00 AM
  5. OT: Where to buy WB02 in Aust.
    By jsttry in forum General (Petrol, Gas, Ethanol)
    Last Post: September 27th, 2005, 03:26 AM
