Results 11 to 20 of 30
Thread: How do you do a segment swap?
    1SH, did the 12212156 file work out (does your 'Hoe run...?)...?
    Senior Member 1SlowHoe's Avatar
    Apr 2006
    It did! I drove it home today. I even did a little brake stalling and tire burning to ensure proper operation
    EDIT: Actually I had to find the same OS. The 12212156 OS didnt work.
    Driving a truck with a BLOWN engine has two meanings. I get to experience BOTH on a regular basis
    2006 GTO....in progress
    2002 6L/80E/Radix/ Tahoe
    What steps did you do...?
    (edit: note to self: he started with 4L60E 12216125).
    Apr 2006
    I took the tune from a 8.1L/4L80E, same OS as mine. 12216125
    I opened it and my dyno tune, then just followed the steps in the segment copy directions. I copied the trans calibration and trans diagnostic segments into my dyno tune and loaded it in the PCM. I started up and ran great first try. It works wonders when you can find the same OS to copy from.
    Thanks for helping me out
    Jul 2008
    what if you have OS 09381344?
    this is the only missing link in my 4L80e conversion...
    thanks!
    forged LS1 I Patriot Stage III heads I Patrick G spec'd TR grind Comp Cam I ProCharger I High Tech Transmissions I Ultimate Converter Concepts I tuned by cablebandit (soon to be me) @ MSS I Exotic Exhaust & Fabrication custom exhaust
    Aug 2005
    Quote Originally Posted by Superado View Post
    thanks!
    For your truck, I'd suggest bumping up to an 01 or 02 OS before doing a segment swap. 12212156 for example. Could then run a COS as well.
    Justin
    Jul 2008
    got the 4L80e segments for my OS...
    was very easy to swap segments and seems to work fine...
  9. #19
    If it's ok with you, can I eyeball your file... ...thanks.
  10. #20
    Jul 2008
    here ya' go...
    please look at it for the issue I posted in a couple other threads as well...
    thanks!
    ANY suggestions are greatly appreciated!
    very new to tuning...
  1. need help with segment swap on 0411 ecm
    By stroker97k1500 in forum Vortec V6/V8 Specific
    Last Post: May 22nd, 2010, 11:42 AM
  2. 4l80e segment swap!!!
    By hyderm87 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 14th, 2009, 03:28 PM
  3. 4l80e segment swap!!!
    By hyderm87 in forum Custom Operating Systems
    Last Post: May 12th, 2009, 03:29 AM
  4. A4 to M6 segment swap help
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2009, 10:24 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 07:14 PM
