Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Newbie Question about Knock Retard
    Jul 2007
    Default Newbie Question about Knock Retard
    Logged my car earlier and the knock retard showed (9.3) in red. The one next to it showed 0.0. I was just wondering what that meant? Also, the afr commander shows about 14.6 cruising and around 12.5 under load, is that good? Sorry for the dumb questions.. lol.
    Powerhouse, welcome to the forum...
    Any KR is not good, it means the PCM detected knocking and is reducing ignition timing to prevent it; either it's real knock (which may or may not be audible; 9 degrees of KR would be...), or it's false (knock sensors picking up valvetrain noise, or other reason...).
    Your commanded AFR's look right.
    I'm not sure what that is, can you post a pic (see howto post #2: http://forum.efilive.com/showthread.php?t=3064 )
    If you saved a log file, can you post it this thread.
    Not dumb questions... it would be dumb to not ask...
    Joe
    Jul 2007
    Yeah, i have a log.. I'll upload it in a second
    Jul 2007
    Here is the log file. It's towards the 11.12.37sec mark.
    http://files-upload.com/389731/Log_0001.efi.html
    You HAVE to click on the link. You can't right click save as..
    Jul 2007
    What would knock sound? Also.. my car is a 2000 Camaro SS M6 with:
    Futral F14 cam 232"/234" .598 "/.598" 112LSA
    Patriot dual Gold Extreme valve springs
    Comp cams Chrome Moly Pushrods 7.400 (Stock Length)
    Futral motorsports ported LS6 oil pump
    LS2 timing Chain
    90mm FAST intake manifold
    90mm Nick Williams Throttle Body
    30lb SVO injectors
    Mac Mid Length Headers
    Off road ypipe
    QTP electric cutout
    Mac hi-flow muffler welded in stock cat-back
    MTI lid w/K&N
    Nitro Dave’s 90mm Plate nitrous system
    NX Bottle Heater
    Nitro Daves console switch center
    860 Spare tire well Bottle mount
    Nitrous outlet solenoid brackets
    Nitrous outlet digital dual window Switch
    LC-1 Wideband o2 sensor
    Optima red top
    I don't really hear anything out of the ordinary and it only does it in first gear.
    Quote Originally Posted by Powerhouse
    Sounds like popcorn popping, or marbles bouncing around; if it was happening, you would hear it at open throttle as you increase RPM.
    Jul 2007
    It only does it in first though... wouldn't it do it in all gears?
    You have an LM1 wideband connected, is it calibrated...?
    Your LM1 is indicating very lean actual AFR...
    1st gear: actual AFR 20+ very lean, very very bad.
    2nd,3rd: actual AFR 16-18 very lean, also bad.
    You're already aware that lean promotes knocking.
    If your LM1 is calibrated (or even if it's not), do not drive the car until you get this resolved.
    You say you can't hear any knock...?
    The knock sensors may be picking up valvetrain noise, but your actual AFR is indicated very lean by your LM1.
    LM1 AFR/BEN indicates your VE, MAF, IFR tables are not dialed in.
    The KR shown in 1st gear has sawtooth jaggedness, indicating that it's probably real knock, and it's duration is sustained for 4+ seconds;
    remove a few spark plugs and inspect them (take pics) for signs of detonation/preignition.
    Also, you may have a little too much ignition advance.
    Jul 2007
    Well fawk. Let me load up my tune so maybe you can check it out
    Wait, you said you have an LC-1 installed...?
    An LC-1 and not an LM-1, right...?
    In that case we need to log the LC-1 AFR/BEN pids.
  1. Knock Retard follows RPM
    By vortecfcar in forum Gen III V8 Specific
    Last Post: June 1st, 2008, 06:02 AM
  2. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    Last Post: March 9th, 2008, 04:18 AM
  3. Knock Retard
    By NAH in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 21st, 2007, 11:15 AM
  4. Knock Retard
    By NAH in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2007, 07:29 AM
  5. knock retard
    By blackblowngto in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2005, 11:50 AM
