Results 1 to 10 of 15
Thread: Continuing V2 Problems
    Oct 2005
    Default Continuing V2 Problems
    Rather than waiting for emails that have been no help, I'll see if others have this same paperweight.
    Just updated from the most current 'stable' version, and again have the same issues with LLY and LBZ Bosch ECMs I had a couple months back. I'm probably one of the few that have 'stream' purchased for these ?
    When I updated initially this past December/January the V2 was working fine. Then (crap) I downloaded an update. Everything worked fine EXCEPT anything BOSCH ecm related.
    After sending (3) V2 units back and forth (yes 3 of 'em) over a 3 month period of continual hassle, I discovered the problem with how the software will install if you run it from a CD.
    Stupid me...I thought I should update to the latest version again this past week.
    Whether that was coincidence or not yet, I still can't verify as I've tried again to duplicate what was wrong last time, and it still won't work. I get the same error as though I'm not even connected. "CONNECTION TO ECM HAS BEEN LOST. PLEASE CHECK ALL CABLES, PLUGS and CONNECTIONS, Make sure the ignition is switched on, then try again" .... and again, and again.
    I can read and program any other computer OTHER THAN an 2006-2007 LLY or 2006-2007 LBZ BOSCH ecms. So I'd think it unlikely its a V2 problem, unless it can no longer work with any CAN communications.
    Is there some kind of listing somewhere to see what might be missing in my 'install' so I can see what files are 'supposed to be there ?
    Yes, I've verified my 'stream' information. I'd assume an error if you gave me the wrong stream info.
    Updating firmware didn't solve anything.
    Yes, I've selected the correct controller. Geez....c'mon ?
    Yes, I've just again installed the newest software.
    Yes, I've uninstalled and reinstalled the latest FTDI drivers again (10th time at least).
    I can program these same Bosch ECM's on the bench with GM's SPS system all day long, but can't read them out again with EFILive. I do NOT have this problem with your competitors' software on a separate computer (I knew you'd ask if it was on the same computer).
    Matt
    Hi Matt,
    When you had the units replaced, did you also have the cable between FlashScan and the vehicle replaced? There may be fault in the CAN pins/wires in the cable. Does the scanner work on the same vehicles that report this error? That would show if the actual cable is faulty or not.
    Which version of the software are you running.
    The latest V7.4.2 version has build numbers:
    • EFILive_Scan.exe build 534
    • ObdiiV7.dll build 666
    • EFILive_Tune.exe build 657
    • FlashScan Firmware version 2.4.60
    It has been uploaded to our web site but the link has not been published yet. The links will be posted on our main web site download page and in this forum shortly: http://forum.efilive.com/forumdisplay.php?f=67 (look for a new post dated today).
    If you re-run the installation program and select the repair option, it will verify all files in the install and correct any missing or damaged files.
    Lifetime Member Doc's Avatar
    Oct 2005
    Not to sound like a tool or a stooge but given the experiences you have related, the first thing in my mind was what about the cable?
    I own a stream too, big deal. I have never gotten the impression that, that means anything in EFI Live's eyes/mind/forum beyond what a user/ customer that only has the most elementry of EFI Live product. You don't have to pass a test or anything just, pay for it.
    Ok, I am not calling you out on this....you decided to make this matter public.
    I will say publicly that I do have some constructive critisim of the V2 with regard to the cables; Both cables (To laptop and to Data port from the V2) are prone to becoming unseated, as they donot have a positive locking mechanism, which can cause weird stuff like what has been described in this thread all too often in my expirence.
    Fortuneatly, my 17+ years with working on US Navy Fighter planes has taught me to be overly suspicious of intermitent connections.
    Throwing out the "Competition" comment only reinforces my belief that if you can make it work with something else then, you should be able to make it work with Live.
    Wether you intended it or not; I interpreted this post as a flame or threat,(take it for what it's worth) which IMHO is totally uncalled for as I feel that this site/product is the best out there as far as communication btw members/ members/ company sharing ideas/knowledge.
    And with that blowhard rant, I still would like to offer any further help as a fellow EFI Live member/customer.
    www.efialchemy.com
    www.greatamericancarwar.com
    Oct 2005
    Hi Matt,
    Everything was working fine till the past software update.
    I'll try the new download...sorry for anything negative, I'm just very frustrated.
    Matt.
    Oct 2005
    Quote Originally Posted by Doc
    That was basically stated because I keep getting told it's my connection, computer or ... I don't even think it's the V2 unit (couldn't have gotten 4 bad ones). It's possibly how XP is registering the program info, too...just not sure. I'm going to try the latest. It's just had a lot of bugs for me from the word go.
    Matt.
    Oct 2005
    JUst installed the latest update, and rechecked firmware. I still get the same message as though it's not connected to the ECM.
    If I query the Bosch ECM directly (Engine controller info) from the V2 unit, I get the following on the V2 screen.
    VIN: ]
    Serial: ' ]
    BCC: <-
    Hardware: 68222976
    I've checked continuity on the cable (ethernet to ODB2/CAN)--each is good and no shorts.
    If I query a non CAN vehicle (example) 2000 GM truck, I can read VIN, serial, BCC and ECM hardware number just fine, and I can download as well as reprogram to that ECM.
    Whatever is wrong with this 4th V2 unit seems to be CAN based ?
    Matt
    If this has been asked before, then please ignore it...
    Is laptop used for connection to vehicle being powered from its own battery, or from wall outlet, or from vehicle's own power...?
    Oct 2005
    Laptop or PC in the shop no difference.
    I use a BK Precision lab powersupply through a RV battery as a buffer, at a constant 12.6 volts for the offboard ECM programming.
    Laptop is plugged in when in the shop.
    At any rate, that's not the problem.
    Matt
    Oct 2005
    Is there anything else to try as I cannott be without this V2 for another 2-3 weeks between shipping and sending and waiting for stream information.
    Please help.
    Matt
    Hi Matt,
    Using the Scan Tool software, connect to the CAN controller and select menu option: Info->PCM info. If an error occurs, please save the error report and email it to me. If an error does not occur, please generate one manually using menu option: File->Generate error report and email it to me.
    Send to paul@efilive.com.
  1. V2 problems
    By GAMEOVER in forum FlashScan V2
    Last Post: January 17th, 2009, 01:05 PM
  2. 2 problems
    By 1fastgto in forum Gen IV V8 Specific
    Last Post: December 26th, 2008, 05:27 AM
  3. E38 VVE problems
    By johnv in forum E37, E38 & E67 PFI ECM's
    Last Post: April 26th, 2008, 12:09 PM
  4. Serious problems again - please help
    By Boost in forum Gen III V8 Specific
    Last Post: September 10th, 2007, 12:12 PM
  5. lc1 problems
    By woody69 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 07:39 AM
