Results 1 to 10 of 20
Thread: Newbie
    Mar 2007
    Default Newbie
    Hi guys, I was looking for a newbie section but wasn't able to find it.
    anyway, i just got a hold of an ALDL cable (usb type) but can't seem to figure my way around checking for codes. and yeah am using offcourse efi
    i have a 95 saturn, i got all the connections right but no matter where I go I can't seem to get any error readings.
    any help for this confused newbie
    thanks
    Leo
    Mar 2007
    anyone?....
    Leo,
    Welcome to the forum.
    You have the AutoTap cable with USB...?
    Which version of EFILive do you have (V4, V5, V6, V7)...?
    Joe
    Mar 2007
    i have this...
    http://aldlcable.com/bigphotos/8950.jpg
    and i'm using v4 evaluation copy
    whe i hit the green button on top i just see values after values...can't seem to get any codes out of it
    thanks joe
    I presume you are using the LL0.xml data stream definition file.
    I just checked that file and it looks like there is no DTC codes defined in it - yet. If you're interested in adding them in, I can send you the necessary information. Let me know.
    Mar 2007
    ye am using LLO...will it be complicated to add definitions on them?
    where do i get the codes and definitions...if you can show me how...i think i can work on it...
    Quote Originally Posted by Pn2r
    Its not difficult just tedious. Its only case of typing in the details and matching the correct numbers to the trouble codes. Send me your email address (to [email protected]) and I'll send you the data and instructions on what you need to do.
    Mar 2007
    email sent...with thanks
    Leo
    Jul 2007
    A newbe here to and I'm having problems getting the software to pickup the com port.
    this is what I get
    58:03.617: Initialising...
    58:03.953: Opening COM1 8228,8,N,1
    58:03.953: Can't open Com1. Access is denied.
    58:03.997: Ready.
    Any ideas ?
    It may be the modem in your laptop (or computer) is using COM1. Take a look in the hardware manager to see which COMprots are available.
    To get to the hardware manager press the Windows key and while holding down the windows key, press and release the "pause/Break" key. Then select the Hardware tab page, then click on the [Device Manager] button. Loacte the entry: Ports (COM & LPT), expand it and see which COM ports are available.
    (XP instructions - these may vary slightly for Win2K and Win98)
    Then, back in EFILive try each of the COM ports in turn.
    Note: EFILive V4 will not work with a USB-Serial com port adapter. You must use a real serial port or use a purpose build ALDL-USB cable.
  1. Hello Newbie
    By 001FAZ in forum Lounge
    Last Post: March 12th, 2009, 03:18 AM
  2. Newbie???'s
    By bdr2008 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 11th, 2008, 04:46 AM
  3. Newbie
    By larshep in forum Gen III V8 Specific
    Last Post: November 15th, 2007, 06:59 AM
  4. Newbie
    By Pn2r in forum General
    Last Post: March 17th, 2007, 06:24 PM
  5. Newbie needs big help bad
    By LowETz in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2006, 11:22 AM
