Results 1 to 4 of 4
Thread: Tire pressure sensors
    Apr 2006
    Default Tire pressure sensors
    My wife's 06 suburban has a faulty tire pressure sensor. We don't want to go through the hassle of dealer (aftermarket tires/wheels) and would just like to disable tire sensors all together.
    I didn't see anywhere that this is an option in the tune, but I'm an idiot with gas stuff. Any help would be much appreciated.
    Thanks,
    Rob
    Jun 2005
    It may be a part of the BCM. I believe the C5/C6 cars sometimes opt for simulators. But, I'm not 100% on that.
    Member JAY4SPEED's Avatar
    Mar 2007
    The tire pressure monitoring system for that year and model is monitored by the passenger door module. The same module that works your key less entry and all functions of the passenger door. To disable it, that would require a Tech 2 and access to Tis2web and a module re-flash.
    You won't find a dealer (including me) that will disable the system for you, too many liability issues, besides it will be a federally mandated safety feature soon on all new vehicles.
    However, I've changed TPS sensors in aftermarket rims for customers before (not under warranty). I guess that would be up to that service department's policy. Wouldn't hurt to call up and ask. You could always get your rim shop to install it for you and I can give you the run down on how to program it.
    Jay
    Mar 2007
    So I take it I can't disable this on a vette either? I have access to a tech2. Is it possible to do with a tech2?
  1. Tire pressure monitor
    By sixltrbtr in forum Lounge
    Last Post: September 4th, 2009, 09:57 AM
  2. Tire Pressure Monitor Adjustment
    By calraj in forum General
    Last Post: July 7th, 2009, 01:13 PM
  3. Change a tire ...
    By Garry in forum Lounge
    Last Post: September 21st, 2008, 06:07 PM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  5. Tire Information
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 10:56 AM
