Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Problems linking the scanner and the editor
    Quote Originally Posted by emarkay
    Dunno, but 3 well-versed users having same prob, leads me to think some clue needs to be added somewhere. Is this possible, maybe as a roll over or maybe some "if no workee, try the following..." box???
    MRK
    I would think we need to standardise the installation for a newby ( and us dumb ass oldy's) so it asks upo installation if you want metric and imperial , also some added setup options upon installation - ie do you want to ue your defualt pids dash etc .
    I seem to have lost the option to automatically validated pids on startup - what setting have I forgotten ?
    MRK
    Hmmm, I though the same thing - it's even caught me out :oops: :oops:
    Quote Originally Posted by Delco
    The current installer checks for the windows localization setting and if it is "US - English" then all settings default to imperial. Otherwise all settings default to metric.
    The problem really occurs when you change a chart or gauge to metric while leaving the default PID settings (on the [Data F8]) tab page.
    PIDs will only be auto validated when a VIN is encountered that has not been encountered before. Only the first 9 and 11th chars/digits are used in the comparison. (the 10th is a checkdigit and 12-17 are a sequence number which are all ignored).
    You can manually re-validate PIDs with Shift+F2.
    or delete all the *.vpl files - that will cause PID validation to occur for each new VIN type, because no matching *.vpl (validated pid list) files will be found.
    Thanks for that Paul , I will delete that file because lately it is coming up with lots of invalid pids unless I validate them - my version has been played with that many times I should delete it and start fro a fresh installation :oops:
  1. Linking Logs to tune?
    By Cougar281 in forum General
    Last Post: August 4th, 2007, 10:31 AM
  2. Linking Scan Log To Tune File Maps
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: July 30th, 2007, 06:33 PM
  3. Scanner help
    By wickedred in forum General (Petrol, Gas, Ethanol)
    Last Post: June 22nd, 2007, 11:10 AM
  4. linking scan data to tune file
    By a78turbo in forum Duramax LLY
    Last Post: March 14th, 2006, 04:53 PM
  5. Linking discrepency
    By Nox in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2005, 06:10 PM
