Results 1 to 10 of 12
Thread: Cat Converter Over Temp Protection
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Default Cat Converter Over Temp Protection
    I got a question for some of you knowledgable guys out there.
    I mate of mine recently had an issue with a brand new Cat Converter that had all its 'guts' crumble and block the exhaust. When he took it back to the exhaust place to get it changed, they said Cats are very sensitive to the gasses run through them and could fail due to some of the following reasons:
    1- running too lean
    2- running too rich
    3- Lead contaminates
    I have heard of this before.
    Now, in our LS1 systems, we have this over temp protection, it will richen the A/F to help cool the cats.
    Does this not create a problem to try to solve another?
    If you richen the mixture, there will be an incomplete burn of fuel causing the leftover fuel to go through the cats which are not good for them???
    Dave.
    Overly rich causes the cats to burn the excess fuel causing the cats to glow bright orange/red...
    they will get internally damaged if this condition is prolonged (say more than a few days worth of driving).
    Redline Motorsports
    Guest
    You'd think with GM's overly rich commanded AFR's in PE mode, more converters don't burn up!
    Quote Originally Posted by Redline Motorsports
    GM's PE is fairly rich and does heat up the cats pretty hot, but it's nowhere near what happens if you have 1 or 2 cylinders not firing.
    GM's idea is to make the cats last just a little longer than their warranty... :|
    May 2007
    how do high flow cats cope? Are they able to handle the abuse a little more?
    The hiflow cats (metallic substrate) are more robust than the stock cats (ceramic substrate)...
    so I would imagine they could handle more abuse.
    May 2007
    here's hoping!
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Actually, "robustness" doesn't have much to do with converter failures. What kills converters are high levels of hydrocarbons in the exhaust stream. Under normal circumstances, converter core temperatures run between 1000 and 1200 degrees (F). When an engine runs extremely rich, a fair amount of unburned fuel enters the exhaust system and when it hits the alread hot converter core, internal temperatures can exceed 2200 degrees, at which point you have converter melt-down.
    Converter over-temp protection utilizes a relatively rich mixture to lower EGTs, and consequently cool the converter down a bit. As long as combustion remains efficient the strategy works. However, in cases of modified engines, if actual air/fuel ratios are very far off of commanded, the strategy can cause more problems than it cures (if the mixture is so rich that it causes unburned fuel to exit the combustion chambers).
    The best way to put converter operation into perspective is to understand that a catalytic converter doesn't "do" anything-- it causes a reaction to occur. The intensity of those reactions is strictly a result of pollutant levels in the exhaust stream. If combustion inside the enigne was 100% efficient and there were no pollutants remaining after combustion, converter core temperature would not be any higher that exhaust gas temperature.
    One of the reasons that engines with long duration cams frequently have converter problems is that the excessive overlap allows a lot of unburned fuel to enter the exhaust stream.
    Hope this helps.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Oct 2005
    FWIW, cats are covered in the US for 80,000 by govt. regulation.
    Redline Motorsports
    Guest
    DFE,
    Nice explaination. Seems to me that after a "good" performancec tune, COT is not really going to be an issue. The way GM sets up there WOT fueling it sounds like they cause more of the issue then us guys that modify the tunes!
  1. Engine/Piston Protection mode..
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: September 13th, 2009, 10:28 AM
  2. E38 PE and Cat Protection Truck question
    By ssvolvo in forum E37, E38 & E67 PFI ECM's
    Last Post: November 12th, 2008, 11:03 AM
  3. Engine Protection
    By ALRAJHI in forum E37, E38 & E67 PFI ECM's
    Last Post: June 27th, 2008, 06:37 PM
  4. what is catalitic protection
    By dsmlights in forum Gen III V8 Specific
    Last Post: December 7th, 2007, 03:14 AM
  5. Temp effect on AFR?
    By 98WS6_JPM in forum General (Petrol, Gas, Ethanol)
    Last Post: March 7th, 2006, 05:49 PM
