I have a 99 K2500 Burb with the 7400/L29/454, tuned by Jesse (love the tune, great power). But the previous owners (a corp vehicle) must have installed larger injectors, I suspect to run a higher % of ethanol fuel, if not E85, but I can't confirm.
It always runs rich, unless I run a nice dose of E85 (40% or so) and BLM/LTFT come down to 0%. With pure gas (no Ethanol) the LTFT runs -18.0% stable. Not 18.1%, not 17.9%. Precisely 18.0%. If a fuel leak like a leaky FPR, it would NOT be that precise. And fuel pressure is dead on GM specs, and does not bleed or leak down when not running.
So, do I recalc the injector size for 18% larger to LTFT come in line?
I am just tired of having it run rich (yes, the O2's are new, old ones were really ok, FPR is good, new unrestricted air filter, new plugs, good wires, good cap/rotor, vapor canister ok, etc, yeah, I have gone through it all).
What would the best way to figure it out with a mail order tuner?
Sheesh, I am ready to descreen the MAF just to screw up the A/F to lean it out!
Thanks!!
