Help me sort this piece out. I already have EFIlive V2. I already licensed my unit to the ecu. If i have my ecu sent in and modified, when it comes back will i need to purchase another license with EFILive to update it?
The RoadRunner license is the US$199 cost of the package. This PCM is tune through the Tune Tool directly connected to the RoadRunner (i.e does not go through V2).
Is more a question for Craig as to whether the PCM serial number (which FlashScan V1/V2 license against) is going to change - I'd expect not if he is using your PCM.
Andrew
EFILive Crew
Well then in theory, as long as my PCM stays the same, meaning i get the same one back, i will be able to use my current software and licensing, just not the flashscan v2 hardware. So not all is lost in vain since i have a lb7.
Ill prob want to RR that as well
Originally Posted by Tordne
