Results 1 to 10 of 14
Thread: Virtual VE table update?
    May 2007
    Default Virtual VE table update?
    Any word on the release of the virtual VE tables update? just curious if beta testing went OK. I'm kind of antsy to try a 2 bar VEtune
    Ed
    Hi Ed, everything seems to be going fine, just a couple of little things we needed to fix up.
    We also added in locking for the E38 / E67. This will be in the Virtual VE update release so just a little bit of testing for that and it's all good to go. I'd say by the weekend it should be posted up.
    May 2007
    Sounds good Ross!
    Here's a couple pics of the car that's been sitting on the other side of my shop laughing at me for the last couple weeks
    It's already made 625 RWHP on 6 PSI, with the MAF, but it has some driveability issues I would like to sort out
    Ed
ID:	2022   Click image for larger version.
    Ed,
    Is that a P1-SC? Stock motor, stock manifolds?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Quote Originally Posted by Ed@Late Model Speed
    Sounds good Ross!
    Ed
    Making me jealous doesn't help Ed
    May 2007
    no, really, I can literally hear it laughing at me......
    Howard, yes P1-SC-1, Kooks 1-7/8" headers, 3" x-pipe w/highflow cats
    I think it's pretty similar to yours.
    Ed
    Awesome.
    Numbers sound right in line.
    Here was mine on 4.0 psi.
    What kind of drivability issues are you having? Are you using 60 lb Motrons?
    How are you coolant temps?
    1-954-703-5560
    May 2007
    Nice! you're making about the same as ours with 2 lbs less boost! Good job
    yep, 60lb Motrons, coolant temps are 185-190 but I haven't driven it real hard. It does have a 160 stat. I'm real happy with everything, except, on cold start it's fine for 2-3 sec, then goes super lean (19.0-20.0:1 ) for about 30-45 seconds, no trottle response, almost dies, then it smooths out and everythings fine? This is only on startup, whether it's cold from overnight, or re-start after sitting for 5 min.
    I can drive the car normally, or get into boost at will, and it never so much as hiccups any time, but that deal on startup makes it act like an old big block with no choke!
    Any thoughts?
    Ed,
    I would be interested at looking your tune and we can talk "offline". I'd love to help you with this.
    Howard
    1-954-703-5560
    May 2007
    Quote Originally Posted by Redline Motorsports
    Ed,
    Howard
    I would really like that, I PM'd you my cell #
    Thanks,
    Ed
  1. Virtual ve table
    By Ls1joe in forum E37, E38 & E67 PFI ECM's
    Last Post: May 14th, 2009, 11:31 PM
  2. Okay question on the virtual ve table
    By chrleb2 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 21st, 2008, 09:20 AM
  3. Virtual VE table not showing up
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 01:08 PM
  4. E38/E67 ECM Speed Density Virtual VE table
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: May 18th, 2008, 08:51 AM
