Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Math for the VE multiplier
    Lifetime Member Doc's Avatar
    Oct 2005
    Have you tried logging batt V / monitor Alt output? I found that my stock alt couldn't keep up with running the fans more, bottle heater, LC-1, FP sensor, Big Bon Jovi stereo, etc. Granted the Vette has a larger alt than the Fbody but, still before you condem the pump you have to ask yourself is it getting enough juice?
    www.efialchemy.com
    www.greatamericancarwar.com
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Quote Originally Posted by Doc
    LOL Bon Jovi? You from Jersey? What Exit
    I will check it out and log voltages, but back on topic...is the math on track that I got going?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Oct 2005
    I think you are on track for with the math but, I wouldn't want you trying to enrich to overcome a possible physical/electrical weakness of your fuel system.
    www.efialchemy.com
    Jul 2006
    I am actually trying to lean out the 10.9 to get mid 11's-11.8 at the tail end of the dry nitrous runs. The richening is in the beginning and is less than a second.
    Maine USA
  1. Somebody check my IFR math - won't start now!
    By Mr. P. in forum Gen III V8 Specific
    Last Post: September 9th, 2009, 05:44 PM
  2. WB Volts vs. AFR math needed!
    By Redline Motorsports in forum General
    Last Post: March 12th, 2009, 04:54 AM
  3. Math needed for gms/sec vs lbs/minute
    Last Post: October 23rd, 2006, 10:45 AM
  4. Math ?
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 9th, 2005, 02:00 AM
  5. Math Wizzards - BEN Factor IAT correction
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2005, 02:56 PM
