Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Tuning Info
    Feb 2007
    Default Tuning Info
    Some info i put together from the web
    May 2007
    nice post gelf!
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    I think there are different assumptions for PE or WOT. 14.7 there would be a threat to all that you hold dear.
    PowrMax Performance
    100 mm PowrMAF
    Nov 2006
    isn`t stoich 14.63?
    Jan 2007
    Quote Originally Posted by mr.prick
    isn`t stoich 14.63?
    Yes it is...and that's where the Auto VE tutorial is wrong/misleading also.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jun 2006
    Nice info, tnx!
    Garry Glendown * '17 Fifty 2SS MT
    Lifetime Member JezzaB's Avatar
    Nov 2006
    isn`t stoich 14.63?
    Suppose it depends on how many decimal places you are showing
    Stoich for gasline is published as being 14.68 which is ~14.7.
    Feb 2007
    Quote Originally Posted by hquick
    How is the VE tutorial misleading? Its states 14.63, is this because you don't want to command stoich during AutoVE and you should command 14.7 like I have read in COS threads?
    Jan 2007
    Yep!
    Howard
    DUCT TAPE.
  1. Idle Tuning - Helpful Info Inside
    By SSpdDmon in forum Tutorials
    Last Post: September 5th, 2017, 09:54 AM
  2. Idle tuning... more info on tutorial please!
    By vxleather in forum Tutorials
    Last Post: July 16th, 2008, 12:11 PM
  3. tuning info
    By ExtTB in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: September 23rd, 2007, 02:21 AM
  4. LS2 tuning info
    By minytrker in forum Gen IV V8 Specific
    Last Post: June 24th, 2007, 01:37 AM
  5. Info on my tuning for 1000 hp!
    By nitrorocket in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 23rd, 2006, 04:47 AM
