Results 1 to 10 of 13
Thread: Pre release 7.5.1
    Feb 2007
    Default Pre release 7.5.1
    There is no mention of BB logging or LC-1 to serial port implimentation in the readme file? I thought this was to be included in this update?
    Oct 2004
    The 7.5.x update includes the Virtual VE update. The other updates will be in the form of firmware updates for the FlashScan V2.
    Just as an FYI (and not to start another thread), but Black Box logging has just started being beta tested on the AutoCal hardware. This will then be ported to the FlashScan V2.
    Andrew
    EFILive Crew
    Jan 2007
    Just installed but haven't tested.
    Has the DFCO bit been id'ed yet? Someone on this fourm said something about it existing but not ID'ed.
    Quote Originally Posted by 2002_z28_six_speed
    GM.STATE05... I see it there but haven't read it yet.
    Jun 2006
    Is the any chance that both scan & flash will uniformly use locale settings or not? Scan 7.5.1 still uses locale settings, whereas Flash still doesn't ... :(
    If it's to hard to get it into Flash, can't you just disable it in the Scan tune?
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Quote Originally Posted by Garry
    Don't understand what you are saying, but wish I did cause I think it relates to switching back and forth between Scan and Tune???
    PowrMax Performance
    100 mm PowrMAF
    Jun 2006
    yes and no ...
    If EFILive is running on a non-US PC (i.e., one that has a locale that uses "," as a decimal delimiter), Scan will use it for fractional numbers, e.g. "14,63". Flash tool, in contrast, doesn't honor this, using "14.63" no matter what the locale setting ...
    Up to that point, it isn't a real problem - until you start doing some tuning, copying data from Scan to Flash (e.g. during AutoVE tuning). The multiply will fail, as the copied data with the "," doesn't work with the "." in Flash ...
    I reported this problem quite some time ago ...
    Oct 2003
    Aaah, well, ok
    PowrMax Performance
    100 mm PowrMAF
    Hi Garry,
    I'll look into it again, but last time (if I recall correctly) I could not make it fail the way you described. Can you tell me exactly which non-US locale you have selected?
    Or is it just any locale that uses "," for decimal placeholder?
    yes and no ...
    Jun 2006
    I reckon any ","-locale should do ...
  1. EFI not same release as V2?
    By RPM Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2008, 05:57 PM
  2. New release 533
    By eboggs_jkvl in forum FlashScan V2
    Last Post: July 12th, 2007, 02:34 AM
  3. Pre release FYI
    By Techfan in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2006, 10:42 AM
  4. V7.1.9 Pre-release is now available
    Last Post: April 13th, 2005, 02:47 PM
