Results 1 to 10 of 12
Thread: C6 A/C not Disabling Under WOT
    5 Liter Eater
    Guest
    Default C6 A/C not Disabling Under WOT
    Hi guys,
    I run HPT 2.2 to tune my '05 C6. There is something that does not seem to work on my car as well as others with the same PCM (E40) ala '05 and '06 GTO's. Not sure if it affects the latter LS2 PCM's. I'm trying to figure out if it is a bug in HPT or the GM OS.
    In HPT, much like EFILive, there are parameters for turning off the AC compressor when a cetain RPM and/or TPS is reached. I've tried all sorts of values for these parameters and log the AC compressor and AC compressor disable status bits and these parameters seem to have no effect.
    So my question is: Can anyone tuning a similar vechicle with EFILive confirm whether this works or not for them?
    5 Liter Eater
    Guest
    Anyone? Bueler?
    5 Liter Eater
    Guest
    Man, there is like zero help over here. Glad I have HPT.
    Sorry man, I dont have a car to test it on. That is an interesting problem, and I know what parameters you are talking about but my truck is a completely PCM, different OS, and would do you no good to know about in regard to your problem (except that these params do affect when it kills the AC compressor).
    Quote Originally Posted by 5 Liter Eater
    Please do look at all the other threads on this forum... can you honestly say that...?
    5 Liter Eater
    Guest
    Yes, I honestly can. There are way more threads about way more topics with way more discussion over on HPT. I honestly think that EFI has a better product where gen 4 PCM's are concerned but the help on the HPT forums is second to none.
    EFILive does have fewer customers than HPT, so there are fewer forum members... it's the forum members that help each other, even on the HPT forums... the help is proportional to the customer base.
    Hopefully someone with an E40 will try your experiment and post an answer.
    Joe
    May I just point out the bleeding obvious for a minute. This forum is specifically for the benefit of EFILive users. It is not a general EFI tuning help forum. If you have a problem with your HPT product I highly recommend getting help from the HPT forum or from HPT support.
    That said, if any EFILive users can answer your question they will. Just because there are no EFILive users that have seen the same problem you are seeing does not mean they don't want to help. It just means no one has an answer for you - yet.
    What did HPT say in response to you logging this problem as a support issue?
    Thumbs down
    Of course, no one may be willing to help you after you made your comment.
  1. disabling a rev limiter
    By bearmtnmartin in forum EFILive V4
    Last Post: May 6th, 2010, 07:36 AM
  2. disabling stock antitheft?
    By thedivineguy in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2009, 02:10 PM
  3. 2010 Camaro Disabling AFM
    By Tommy in forum Gen IV V8 Specific
    Last Post: September 14th, 2009, 09:10 AM
  4. Airbag disabling?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2009, 08:05 AM
  5. Disabling Post injection on LBZ
    Last Post: January 1st, 2009, 11:00 AM
