Ok I am havin probs installing 7.5 I downloaded it to my desktop now what I am pretty unfamiliar with unzipping files, and such. About all I got going for me is I can type, somewhat decent.
Riley
Riley
01 CCSB Chevy 4WD HD LB7, built trans, and some other stuff
Ok I thought I had this figured out, but I dont. If I use the shortcut on the desktop for the tune or scan tool, it is still V7.4 If I go into my computer then c:drive, program files, efilive, It brings up V7.5 Help what did I do?
Riley
What you need to do is follow exactly the instructions on the 7.5.1 download page, they outline what you need to do to the "t".
The contents of zip files must be copied to non-zip folders otherwise they won't work; do as Erik said.
Thanks guys I will get on it here after a bit, been busy in the shop.
Riley
