Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: is lean cruise bad for the engine
    Sep 2007
    Default is lean cruise bad for the engine
    would this affect the life of the engine even if i could do it in my LL8 I-6??
    Jul 2003
    its not bad for the engine. Only problem is if it pings...
    Dec 2006
    I'll have to try to figure out how to enable that. I am getting tons of requests for ecomony tunes. Guess I better read up on custom OS...
    8.7 @ 84 (1/8 mile) bolt-ons
    Well since the LL8s have never been able to do lean cruise like the Holden rides or 04 GTO, I dont know how you'd do it. As Highlander said, shouldnt have any effect unless it pings.
    Jan 2007
    Yes and No.
    If you live in an emissions state they will nail you for the NoX emissions.
    It can be a problem if you don't have it set up well.
    I have tried running the engine at 17:1 for short periods of time. Basically what I have heard is as long as the load is low you will be ok.
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Been running lean cruise for a couple of years now. Just get ready for it to burn the cats up
    Jan 2007
    Not a problem here. No reason at all!
    Senior Member Sid447's Avatar
    Jul 2005
    I was under the impression,
    lean-cruise raises cylinder head temps and thus raises ECT?
    Dec 2006
    My initial thought is that I wouldn't worry about it damaging the engine. Most of the conditions where lean cruise is enabled are very low load anyway. Severe damage occurs at high RPM / load.
    And I thought a rich mixture would cause hotter operating temps, or is that only on the rotary engine?
    On cars with reasonable camshafts you generally can't use it because the lean mixture causes misfiring. The jury is still out on the real world savings lean cruise actually makes, don't think it's going to turn a 6.0L in to a Honda Civic!
  1. Lean cruise tip-in
    By LinearX in forum Tuning For Economy
    Last Post: February 28th, 2010, 02:52 AM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. Lean cruise on 04 GTO
    By 98ls1blackbird in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2007, 02:11 PM
  4. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  5. Lean Cruise - US - LQ4 6.0L - Anyone done it?
    By Zfreak in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2007, 11:58 AM
