Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: BB Logging update Nov 28, 2007
    Default BB Logging update Nov 28, 2007
    Senior Member Hyper99's Avatar
    Oct 2005
    So far so good - Updated fine.
    I like the memory selection feature.
    Will try it in the truck in the morning
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
    Senior Member SV8346's Avatar
    Nov 2007
    i cant get it to go into deadpoll mode, when i hold down the control button and plug it in i get the 2 amber flashing lights back and forward but when i go to check status in the firmware upgrade it says its not in deadpoll mode????
    HELP.......
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Still cant get it to read the PCM. Same as before, unlocks the PCM and gets ready to read etc and then just sits there waiting and waiting with the occasional spurt in activity on the lights.
    Then when i retried the operation it informed me the PCM was locked. Removed the cable, restarted car. Same. Restarted EFILive Tune Tool. Still the same, says its locked. Restarted the computer and it wouldnt say it was locked anymore but still cant read the PCM. This was on an E38 again, dont have an LS1 to try it on tonight.
    Jez
    Nov 2007
    has anyone had this problem before, nothing i can do can get it to go into dead poll mode.
    Junior Member NERDPWR's Avatar
    May 2007
    Upgraded to the new firmware without issue.. Went for a drive Logged some data.. At this stage all seems good..
    BTW 433 / 05 VZ.
    Jan 2004
    Quote Originally Posted by SV8346
    HELP.......
    Exact same thing here. I will check back in this afternoon.
    May 2007
    Quote Originally Posted by XLR8NSS
    You will need to go straight into EFILive Explorer and update the firmware straight to 2.5.09 using the firmware tab if you have already been through the previous beta firmware upgrade....
    Nov 2007
    yep same, upgraded....thanks to NERDPWR. Went for a drive and done a short log all seems good. Will be even better once more pids are available.
    Awesome work blacky!!!
    Maybe I'm doing something wrong, but I'm still not getting any data in standalone. The timer increments, but no frames are logged and no data is displayed next to the PIDs. After teh update, I formatted the config flash and copied all the PMM files and the options.ini back.
    Also, still getting the $0311 when I try to clear DTCs on my LLY.
  1. BB Logging Update Dec 31, 2007
    Last Post: January 9th, 2008, 02:59 AM
  2. BB Logging Update Dec 20, 2007
    Last Post: December 29th, 2007, 09:11 PM
  3. BB Logging update Dec 01, 2007
    Last Post: December 19th, 2007, 12:41 PM
  4. BB Logging Update Dec 14, 2007
    Last Post: December 17th, 2007, 03:26 PM
  5. BB Logging Update Dec 6, 2007
    Last Post: December 13th, 2007, 02:34 PM
