Download these two files:
http://download2.efilive.com/Softwar...751_027_69.zip
and
http://download2.efilive.com/Softwar...811_010_10.zip
Instructions have been updated, see attached Readme_First.rtf file
If you have already upgraded to the new BB logging bootblock, then you do not need to (in fact you cannot) upgrade the bootblock again. Once it has been done you only need to update the V2.05.xx firmware if/when new firmware is released.
There is new firmware that you must program into FlashScan using the programming option in EFILive_Explorer.
The new firmware now allows you to edit the settings here: F4->F2->F3
Each setting can be adjusted using the left and right arrow keys, or the Ctrl+left and Ctrl+right for larger changes.
Use Ctrl+Up and Ctrl+Down to set the max and min values respectively.
Use Ctrl+Backspace to revert settings to factory defaults. (You can also revert to factory defaults by deleting the Settings.dat file from FlashScan's [Config] tab page.
There is a typo in the Readme_First.rft file in step 3 of the
Upgrade the FlashScan firmware to V2.4.69 option, it says:
Load the FlashScan Firmware File:
\Program Files\EFILive\V7\FSProg_V2_4_68.ffw
it should say
\Program Files\EFILive\V7\FSProg_V2_4_69.ffw
