Results 1 to 5 of 5
Thread: Standby Power
    Senior Member SV8346's Avatar
    Nov 2007
    Default Standby Power
    Just a quick question, I'm just wondering what is the standby power consumption of the V2, I'm planning to mount the unit in the car full time and leave the diagnostics cable plug in all the time but this keeps the unit powered up at all times.
    How much wattage or amperage does the unit pull while in standby mode?
    Jan 2005
    I don't know the exact current draw, but I've found I can leave my bird parked and V2 connected for about 7 days. By the seventh day, the bird struggles to start.
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    Quote Originally Posted by TAQuickness
    Is that with the back lighting on the V2 on or off? I'm sure that will make a big difference.
    V2 uses 210-220mA when fully powered up.
    The new BB logging firmware has a low power mode that reduces current draw to around 100mA. The low power mode will be available in the next beta update.
    Low power mode can be manually selected or automatically entered after a user defined idle time has elapsed.
    Any keypress, or USB communications will exit low power mode and return FlashScan to full power.
    Jan 2005
    Quote Originally Posted by kbracing96
    Off. LCD on and the battery is dead as a rock in 7 days
  1. no power in an l76
    By dynarex in forum E37, E38 & E67 PFI ECM's
    Last Post: April 21st, 2008, 11:54 PM
  2. Low power mode and power cycle?
    By SV8346 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 11:40 PM
  3. no power to flashscan
    By sweetdiesel in forum General (Diesel)
    Last Post: July 21st, 2006, 12:25 PM
  4. Where's the power????
    By ronhall512 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2006, 02:27 AM
