I get what you're trying to say. What we're trying to say is the AutoVE is an in-depth procedure that most tuners don't go through the trouble of doing. If you're just interested in dialing in your AFR and timing on the dyno, that is entirely possible. Tweak the timing and play with PE until you get the desired results. However, take note of your fuel trims prior to hopping on the dyno because they will most likely be reset after you flash in a tune. This is important because if they are positive (say 6%) and you dial in the AFR after flashing it a few times when they're at 0%, they're going to go right back to 6% after some driving and they'll carry over to WOT making you 6% too rich.Originally Posted by dsmlights
The 'old school' way of doing things is to notice where the fuel trims are at, make some adjustments to the Inj. Flow Rate table to get them close to zero, and dial in WOT with the PE table. That can be done before and on the dyno using the ltfts and a WB. That's the quick way to get it done....no touching VE unless it's cam'd and you need to pull fuel so it'll idle.
