Paul & Ross - you never cease to impress me.
OS:
02020005
Update to FW 11:
flawless
Checked DTC's:
Functionality works great.
I'm seeing a new DTC of B0245. Only expected P0101-3
Attempt to clear DTC's:
error $0314
BBL to internal memory:
BBL to Sandisk 1gb micro SD (with adapter):
Error Id10t
After formatting my SD card, it worked great
Connected both LC1's to AD1 & AD2:
Was able to monitor the values, but they looked unreasonable
Few suggestions:
- When attempting to log to an SD and the file structure is incorrect - prompt user to format the SD
- Switching between the internal and SD file system is counter intuitive with the current menu structure
- An LCD indication of when you are logging, monitoring, or have paused a log would be nice
