Thread: Tunning friends truck
    Oct 2007
    Default Tunning friends truck
    Alright he has a 1999 Sierra 5.3L .. Well im still new to Efilive, And im wondering what i should tune for without a WB. I'll adjust the shift points, tire size ect.. Should i up the octane tables untill i see KR? Just looking to get some ponies out of the truck. What other tables should i look for when tuning the truck? Or does anyone has a modified tune i can look at? Thanks in advance!
    BB,
    Can also do this:
    - increase shift pressures by 10-15%, and ramp them up right from zero (i.e. no flat spots);
    - decrease shift times to 0.3s;
    - decrease torque reduction to 15-20%;
    - set the throttle kickdown tables to 100%;
    As for tuning, post up some logs showing LTFT's and various other parameters: VSS, RPM, SPARK, KR, AFR, IAT, ECT, GEAR, DYNCYLAIR_DMA, MAP, MAF, TP.
    Might not be a good idea to increase the timing tables until you know what the actual AFR is.
    Joe
    Oct 2007
    I was thinking of logging the hi/low octane tables map and copying the info to the tunning tool, then logging the KR at the same time and adjust it in the tables. Then go up a little by little. Is that the correct way to do it? Will i notice performance gains?
    Lifetime Member Doc's Avatar
    Oct 2005
    You are playing with fire messing with Fuel/Air/Spark with no WB02. You should see a very nice "SAFE" performance gain with the tranny settings alone. Especially, since this is a truck we are talking about. Bottom line,
    GET A WIDEBAND
    www.efialchemy.com
    www.greatamericancarwar.com
    Oct 2007
    I do have a wideband, its just a friends truck that ill be doing a little bit of tunning.. I'm just wondering how can wait4me tune the spark tables without a wideband. Because a stock tune and my tune have very different octane tables.
    Jan 2007
    Ive been tuning my truck and have had it tuned with a 12.4-12.6 AFR and 26-29 degrees of timing at WOT.
    Ive had it like this for almost a year with about 10k on it.
    Ive heard from others who had stock trucks and got a WB that the stock commanded PE is very close to what they see on a WB.
    However i can not really tell the diffrence when I increased the timing from stock to 26-29degrees at WOT. But I don't have a dyno to tell.
    The main thing to do is get rid of the PE delay mode.
    This means at WOT before a certain rpm and time the engine is running at 14.7AFR although it is running pretty low timing.
    I made my timing table based a little off the optimal timing table.
  1. Will be starting on my friends tune soon
    By Spdfrk1990 in forum Gen III V8 Specific
    Last Post: January 24th, 2008, 09:13 AM
  2. Tuning friends truck...need ideas about wideband
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: October 28th, 2007, 06:02 AM
  3. Replies: 5
    Last Post: August 7th, 2006, 03:44 PM
  4. a friends nice words to me..about tuning
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: October 10th, 2005, 12:42 AM
