Results 1 to 9 of 9
Thread: Raodrunner Option Requests:
    Nov 2006
    Default RoadRunner Option Requests:
    i would like the option of selecting how data is applied.
    right now the only way is to multiply,
    which is really only good for BEN factor.
    the option to add, subtract, and multiply can
    be added to the RTACS tab for convenience.
    also a way to combine filters.(RPM and TPS) ect.
    hopefully more people can add to this thread.
    Default Yeah, that would be cool....
    Quote Originally Posted by mr.prick
    Yeah...Good idea!
    Chuck CoW
    Jan 2007
    I'd like to be able to AutoVE my main and Boost VE tables at the same time.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Default go here.....
    Go here.....
    http://forum.efilive.com/showthread....ight=chuck+cow
    Anyone have a use for this feature....I would love to see it....
    Chuck CoW
    Oct 2006
    Quote Originally Posted by Chuck CoW
    Go here.....
    Chuck CoW
    It wont allow me to view that post, must be a secret area
    Jan 2007
    Me either
    Howard
    DUCT TAPE.
    Jan 2005
    Correct. It's in one of the beta areas.
    Quote Originally Posted by 5.7ute
    Here you go.....
    OH, How I love RTACS! Let me count the ways.....
    Bottom line is...IT'S AWESOME!
    However, I have two suggestions....
    1) When RTACS is on and making changes...I would like to be able to copy and paste un-cooperative sections of the BEN table to the VE table while it's adjusting.....When RTACS is ACTIVE, highlighting and copying is not possible....
    2) And, in a similar, and slightly related question.... One thing I've been waiting for/wanting is that while RTACS on, I'd like to have sort of a "FLASH" button or hot-key which would enable me to make quick changes to the VE to bring it closer much quicker.
    While logging I've noticed the stray cells that don't get hit too often and some of the annoying DECEL and below 1200 rpm cells get messy....While I'm aware that you can block them out, I think there would be tremendous value in the "FLASH VE" button....
    The "FLASH VE BUTTON" could be a hot key that would instantly take the BEN FACTOR table and "paste and multiply" it over the VE table so as to make initial dial in quicker....
    If most of your cells are looking good and close to "1" then no problem, but if you have annoying strays that you don't hit often enough...you would be able to tame them much quicker, rather than waiting for RTACS to get around to adjusting them.
    Problem is that RTACSing a vehicle on the street, or worse yet in an automatic, it can get tough to dial in those messy areas.
    I believe that these ideas would make it a much quicker process....
    While driving and RTACSing...I find myself often dreaming of reaching over and hitting the "FLASH VE BUTTON" to make things go quicker....
    Then "SNAP" I wake up and realize that it's only a dream....and it dosen't exist yet.....
    Hey Paul....Think it's do-able?
    Chuck CoW
    Nov 2006
    Here you go.....
    Chuck CoW
    have you tried lowering the update frequency in the properties tab,
    and changing how much of a percentage the RR updates?
  1. PID's, Option.txt?
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 26th, 2010, 01:58 AM
  2. Bad Injector...what's the best option?
    By LBZoom in forum Duramax LB7
    Last Post: April 29th, 2009, 01:11 PM
  3. Table/parameter requests
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2005, 09:13 PM
