Thread: 7.5.1 can not find RR
    Nov 2006
    Default 7.5.1 can not find RR
    i installed 7.5.1 and updated the firmware,and the RR could not be found so,
    i uninstalled the drivers with the FTClean and reinstalled them.
    after doing this 3 times
    i found that version 7.4 (A.K.A 7.5) would connect.
    i have added 7.5.1 to my firewall and i still can`t
    figure out why it won`t see the RR.
    also the RR filters have not migrated for some reason.
    i will also add that making 7.5.1 a stand alone install was IMO
    a bad way to do this.
    i think that a complete uninstall of 7.4 and install of 7.5.1
    would have been better, it has been a pain migrating settings.
    though not to difficult but a pain none the less.
    IMO
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    I got mine going no drama....
    Never had to play with drivers at all. Once you get them right leave them alone.
    Check Com Port number set up, you may have to select "Virtual Com Port" in roadrunner settings.
    Edit/ Properties/ Roadrunner.
    cheers
    Mick
    Rev it up, Drop the clutch, See what happens?
    Nov 2006
    i have found the problem,
    when i opened the properties tab i had this
    virtual com port should be selected.
    i don`t know why this was like this,
    maybe i`m special
    i still think it stinks to have to migrate somethings manually.
    Lifetime Member Doc's Avatar
    Oct 2005
    Just for the benefit of all...Once your RR has been in and out of many different vehicles like mine; the main connector can get stressed and fail. This will drive you nuts looking for software issues when all along it is just the cable.
    www.efialchemy.com
    www.greatamericancarwar.com
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    My filters have transferred fine. I just following the instructions.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Nov 2006
    i ment the filters from the RR tool bar.
    for some reason i had to reset them myself,
    the filter text was transfered as per the read me text after install.
  1. where can I find 0411 pcm ?
    By ammarii in forum Vortec V6/V8 Specific
    Last Post: May 12th, 2015, 04:41 AM
  2. Where do I find EFI Explorer?
    By trailshredder in forum General
    Last Post: April 30th, 2009, 07:59 AM
  3. Who can find the problem?
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 24th, 2008, 10:24 AM
  4. Help...can't find value.
    Last Post: June 28th, 2005, 03:34 PM
