Download these two files:
http://download2.efilive.com/Softwar...752_035_70.zip
and
http://download2.efilive.com/Softwar...016_15(31).zip
The ReadMe_First.rtf file has been updated to list the new features/options in this release.
If you have already upgraded to the new BB logging bootblock, then you do not need to (in fact you cannot) upgrade the bootblock again. Once it has been done, you only need to update the V2.05.xx firmware if/when new firmware is released.
There are two new firmware files:
1. FSProgV2_05_15(31).efw that you must program into FlashScan,
2. ACProgV2_05_15(31).efw that you must program into AutoCal (if you have an AutoCal unit), using the programming option in EFILive_Explorer.
IMPORTANT: AFTER programming the new firmare, you should delete ALL *.pmm files from the config folder in FlashScan and ALL files from the config folder in AutoCal (if you have an AutoCal device). Then copy in the new ones provided in the Config folder of this update. Failure to do so may cause FlashScan and/or AutoCal to fail when an attempt is made to select a vehicle.
The version numbers of the firmware files will not change between now and the final beta version. That means you will be able to re-program older firmware files during the remainder of the beta test period. The date of the firmware file will continue to be updated and it will provide the only true "version" reference and should be quoted when you post problems with any particular firmware "version"
