Thread: 58 tooth reluctor
    Default 58 tooth reluctor
    Hey guys, looking for information. I have a 2007-08 LM7 that I need to run, it has the 58 tooth relutor and I have purchased the E38 PCM. Does this sound right? Do we EFI live people have programming for the E38? Also, is there an older style LS1B computer that would work for this instead or are they all 24 ? Thanks for any help
    Robert
    Just one guy tryin' to make a difference
    Older style LS1/LS6 PCM's only work with 24 tooth reluctors.
    Quote Originally Posted by v8vegaman
    Robert
    Hi Robert, yes you need to run the E38 ECM and yes EFILive can program them so long as you have the V2 hardware.
    I had assumed that as well, I was looking at the tunes on holden crazy and found some 07 LM7 tunes but the PCM type said LS1B, I guess they kept using the 24 into 07. I want to use the 58 engine to get some ls2 and other 58 tooth learning under my belt. Thanks again
    RW
    They are still using the LS1B PCM in 2008!!, it's only on a handful on engines though.
    Thanks again for the info.
    RW
  1. Do I have a 24tooth or 58 tooth ECM?
    By matt in forum Gen IV V8 Specific
    Last Post: August 11th, 2009, 06:40 PM
  2. Holden V8 - reluctor 24x with LS1 PCM
    By Batman in forum Conversions / Aftermarket Parts
    Last Post: July 21st, 2009, 05:36 AM
  3. Holden V8 - reluctor 24x with LS1 PCM
    By Batman in forum Lounge
    Last Post: July 12th, 2009, 11:47 AM
  4. 58 Tooth Wheel Indexing
    By rv6ejguy in forum Gen IV V8 Specific
    Last Post: January 21st, 2009, 08:06 AM
  5. 24>58 reluctor hack??
    Last Post: March 14th, 2006, 02:45 PM
