Results 1 to 5 of 5
Thread: Resetting V2 to get comms
    Apr 2005
    Default Resetting V2 to get comms
    After a re-flash, I have to unplug V2 from the car not the laptop to get comms again, after the update for BB logging. I read that it might be that Hapi is running, I checked that, and it was not. It does this consistantly, and I did some searches and didn't see an update. Am I missing something?
    Jan 2007
    I had this problem.
    I can't remember exactly what I did but I think it was something like this:
    Make sure you have the new stand alone install of EFI-Live 7.5
    Make sure you truly have the most up to date firmware in ur V2
    That solved it for me.
    Apr 2005
    I updated the firmware, it does it less... but still does it from time to time. I only notice it when I go to the scan tool right after a flash. It will show connected, but won't give me the buttons at the bottom of the screen until I disconnect the software, and physically disconnect the V2 from the car. Then it will reconnect as it is suppose to.
    Quote Originally Posted by Jason S.
    We still have not determined what causes that behaviour.
    Just FYI, unplugging from the vehicle causes FlashScan to power-cycle and reboot. I believe that will be what is "fixing" the problem rather than anything related to the FlashScan/Vehicle connection. You should be able to achieve the same result using the key sequence Ctrl+Cancel (reboot) on FlashScan's keypad. Please let me know if that key sequence also "fixes" the problem.
    swingtan
    Guest
    Hi Paul,
    The key press "reset" fixes this problem for me. I normally don't worry about disconnecting, just hit <CNTRL> & <CANCEL>. After doing this it works fine.
    Simon
  1. AFM-1500 serial comms...
    By Redline Motorsports in forum General
    Last Post: November 26th, 2009, 10:07 AM
  2. SDM - No Comms...... Problem
    By Ninety8C5 in forum Lounge
    Last Post: July 8th, 2009, 01:55 PM
  3. Help resetting OS and calabrations to stock
    By warscout2 in forum Custom Operating Systems
    Last Post: October 13th, 2008, 03:38 AM
  4. Resetting TAPS
    By chevyspy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 20th, 2007, 01:50 PM
  5. Resetting all telltales quickly?
    By kp in forum General
    Last Post: April 16th, 2005, 01:31 PM
