Results 1 to 10 of 18
Thread: Running rich ls1 corvette 402 stroker
    Dec 2007
    Question Running rich ls1 corvette 402 stroker
    Does any one no why my car would be running really rich when i have my ifr's set to what they are supposed to be for 42lb injectors and when i set them leaner to 5.507813 it runs really good and idles good now too. When i set the ifr's to 6.110675 it runs terrible. Ive looked at several tunes with 42lb injectors and none of them have their ifr's set as High as the injector calculater says they should be. I must be missing something or miss understanding?
    98 vette, 402 stroker, comps xtreme Advanced dur-273/279, Dur@.050 224/230 lobe sep:114, Comp 1.75 roller rockers, Patriot stg 3 heads, 90mm fast intake,90mm ls2 tb, 42lb/hr bosh injectors, fast fuel rails w/regulator to 58psi, 160 stat, pacesetter headers, slp cats, magna flow x pipe and mufflers, msd 8245 coils and wires, 3:73 gears, and tring learn how to tune with the v2:
    Jan 2007
    Have you tried the auto VE again Adam?
    With the IFR set correctly I imagine it would make a difference.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Yes, now that your IFR table has changed, your VE table will have to change also. And if you were previously MAF-tuned, your MAF table may have to change also.
    Dec 2007
    ok, im not sure how to do a auto ve table, I read the tutorials on doing a ve table, but from what i understand i need a wideband o2, correct? And how do i go about setting my maf correctly? My os is 2156
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Are you sure you have 42-pound injectors? It sounds like they're 36-pounders based on the fact that the engine runs better when you use 5.50 rather than 6.11. That may sound like a stupid question, but I can't tell you how many times I've found injectors that don't flow anywhere near the rate that the seller claimed.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Dec 2007
    Well i am going by what the seller told me on ebay, so i guess you may be right! Is there any marking on them that i can tell. They are the bosh green ones, Let me know thanks Adam
    Dec 2007
    http://users.erols.com/srweiss/tableifc.htm - great table lookup for part numbers.
    http://www.fiveomotorsport.com/Injector_Sets.html - great list of images for cross referencing part numbers.
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
    Good point, I agree with dfe1 and scdyne... look up the part numbers.
    Dec 2007
    You guys were right, i found out i have 40lb instead of 42 lb, and they are a high impediance injector and they are rated at 43.5 psi so should i change my fuel rail pressure to 43.5 instead of 58?
    Measure your rail pressure with maifold reference hose disconnected (it should be 58 psi or close);
    insert this number into the calculation.
    (remember to reconnect the reference hose).
  1. Car is running VERY rich all of a sudden
    By alwaysinboost in forum Custom Operating Systems
    Last Post: June 8th, 2009, 11:01 AM
  2. 5.7 running rich.
    By DmaxHawk in forum Vortec V6/V8 Specific
    Last Post: January 21st, 2009, 06:40 AM
  3. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
  4. 1998 corvette with 402 stroker, help tuning
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: December 25th, 2007, 02:30 AM
  5. It's running a little rich
    Last Post: January 23rd, 2007, 02:30 PM
