Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
Thread: MAF Calibration (No Spreadsheets!)
    Apr 2005
    thanks sinister! this is greatly appreciated.
    Jan 2005
    Now that's good Schtuff!
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Should I keep the MAF after SD or no? That is the question???
    Bill
    8)
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Lifetime Member ZL1Killa's Avatar
    May 2005
    you can keep it or trash it. if you calibrated it in with this map then i would say plug it in and leave it.
    My buddy nick williams knows (and I'm sure that you also know) people that do and don;t have the MAF. Nick is running the MAF and his car is awesome.
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    Apr 2006
    Quote Originally Posted by SinisterSS
    6. Copy and paste the MAF map as a factor into your MAF table in the tune.
    When I do this I paste and multiply with lables right?
    99 C5 6speed LS2 402ci DTE 3.90 diff w/hardened output shaft, FLP headers, No Cats, ZO6 mufflers, Haltech Cobra CAI, Ported Fast 90 and LS2 TB, 42 Delphi, ZO6 Maf, EFI-Live, LC-1 wideband, Comp XE-r 232/236 .598/.605 112+0 lsa, AFR 205 heads milled .036 w/ Cometic .045 gaskets, TR 7.4 pushrods, textrila clutch, ASP underdrive pully, 490rwhp/474rwtq 10.83@130.6 1.59 60ft
    10.96 video
    in car vids
    10.9 runs
    Sep 2003
    Yup
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Quote Originally Posted by MSGHUFF
    You will have to change the column from 8000 to Value,Value
Name:	Clipboard3 (Medium).jpg
    I have been fooling with this for a while and once changed table I could Paste and Multilply but it seems to take my AFRs lean (PLX).
    Let us know how it works out for you -_-.
    PowrMax Performance
    100 mm PowrMAF
    Jun 2005
    In my experience, there's not a direct 1:1 relationship with the MAF and AFR. I usually make partial corrections, which is where Excel does come in handy. That way, I can turn a BEN of 1.05 into 1.025 (50% correction) easily for each frequency. This helps dial things in a little closer and really doesn't take much time at all.
  9. #19
    Oct 2003
    I assume that increasing the value in the MAF table increases the amt of air added?
    In that the AutoVE tunes for no MAF when you throw the MAF back in with it's air correction the MAF air should be ~0 given identical conditions.
    Kinda hard to imagine.
    PowrMax Performance
    100 mm PowrMAF
  10. #20
    Jan 2005
    Bruce
    yes - increasing the value in the MAF table effectively tells the PCM there is more air for the respective Hz value read from the MAF. The MAF calibration is a look uptable similar in nature to the VE table.
    Quote Originally Posted by SSpdDmon
    Have you seen this across the board or down low where the VE and MAF are "blended"?
  1. odd Calibration
    By CalEditor in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2009, 05:38 AM
  2. 02 LC1 calibration using V2
    By waterbug1999 in forum FlashScan V2
    Last Post: May 2nd, 2009, 10:14 AM
  3. Help with MAF calibration
    By dvx in forum General (Petrol, Gas, Ethanol)
    Last Post: July 5th, 2008, 08:37 AM
  4. V2 A/D Calibration - FAQ
    By Blacky in forum FlashScan V2
    Last Post: March 10th, 2007, 10:57 AM
  5. MAF calibration?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: September 5th, 2005, 01:22 PM
