ran several tunes and all is well-but i noticed that the tables b8034,b7902,3,4 all are out of range
so i tried to adjust and they wont go over the max limit-so i said forget it and loaded the tune-well the truck died
i limped it home and read the codes -then checked the history and the tables that i tried to adjust said i changed the values from numbers way above the efi limits even though i didnt change them
this is on a 2008 sierra 1500 l98 auto with the e38ecm
sorry for being unclear -will fix my sig
