Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Moates ALDU1, 8192 baud, and v4 issues.
    Feb 2008
    I'm using the '1995 Pontiac Vin 1' xml file.
    Try changing your vehicle definition settings to the same as these images.
ID:	2759   Click image for larger version.
    Feb 2008
    I changed those particular settings and this is what I got:
    51:51.211: Start macro: Clear diagnostic trouble codes: CLRDTC
    51:51.226: Synchronising ALDL communications...
    51:51.226: Waiting for heartbeat: $A1,$56
    51:51.226: Waiting for Aldl bus silence of at least 20ms...
    51:51.255: Start reading frame
    51:51.300: Aldl frame header byte: $90
    51:51.301: Aldl frame length byte: $59
    51:51.307: Recv: $90,$59,$23,$02,$0E,$5D,$87
    51:51.307: Finished reading frame
    51:51.307: Frame: 0 = $90,$59,$23,$02,$0E,$5D,$87
    51:51.307: Start reading frame
    51:51.310: Aldl frame header byte: $91
    51:51.312: Aldl frame length byte: $59
    51:51.318: Recv: $91,$59,$02,$08,$FF,$34,$D9
    51:51.318: Finished reading frame
    51:51.318: Frame: 1 = $91,$59,$02,$08,$FF,$34,$D9
    51:51.318: Start reading frame
    51:51.325: Aldl frame header byte: $20
    51:51.326: Aldl frame length byte: $5C
    51:51.336: Recv: $20,$5C,$9E,$01,$00,$AF,$20,$00,$4C,$CA
    51:51.336: Finished reading frame
    51:51.336: Frame: 2 = $20,$5C,$9E,$01,$00,$AF,$20,$00,$4C,$CA
    51:51.336: Start reading frame
    51:51.400: Aldl frame header byte: $90
    51:51.401: Aldl frame length byte: $59
    51:51.407: Recv: $90,$59,$24,$02,$0E,$5D,$86
    51:51.407: Finished reading frame
    51:51.407: Frame: 3 = $90,$59,$24,$02,$0E,$5D,$86
    51:51.407: Start reading frame
    51:51.410: Aldl frame header byte: $91
    51:51.411: Aldl frame length byte: $59
    51:51.417: Recv: $91,$59,$02,$08,$FF,$34,$D9
    51:51.417: Finished reading frame
    51:51.417: Frame: 4 = $91,$59,$02,$08,$FF,$34,$D9
    51:51.417: Start reading frame
    51:51.425: Aldl frame header byte: $20
    51:51.426: Aldl frame length byte: $5C
    51:51.436: Recv: $20,$5C,$9E,$01,$00,$B0,$20,$00,$4C,$C9
    51:51.436: Finished reading frame
    51:51.436: Frame: 5 = $20,$5C,$9E,$01,$00,$B0,$20,$00,$4C,$C9
    51:51.436: Start reading frame
    51:51.499: Aldl frame header byte: $90
    51:51.500: Aldl frame length byte: $59
    51:51.506: Recv: $90,$59,$24,$02,$0E,$5D,$86
    51:51.506: Finished reading frame
    51:51.506: Frame: 6 = $90,$59,$24,$02,$0E,$5D,$86
    51:51.506: Start reading frame
    51:51.509: Aldl frame header byte: $91
    51:51.510: Aldl frame length byte: $59
    51:51.516: Recv: $91,$59,$02,$08,$FF,$34,$D9
    51:51.516: Finished reading frame
    51:51.516: Frame: 7 = $91,$59,$02,$08,$FF,$34,$D9
    51:51.516: Start reading frame
    51:51.524: Aldl frame header byte: $20
    51:51.525: Aldl frame length byte: $5C
    51:51.535: Recv: $20,$5C,$9E,$01,$00,$B1,$20,$00,$4C,$C8
    51:51.535: Finished reading frame
    51:51.535: Frame: 8 = $20,$5C,$9E,$01,$00,$B1,$20,$00,$4C,$C8
    51:51.535: Start reading frame
    51:51.550: Aldl frame header byte: $A8
    51:51.551: Aldl frame length byte: $56
    51:51.553: Recv: $A8,$56,$44,$BE
    51:51.553: Finished reading frame
    51:51.553: Frame: 9 = $A8,$56,$44,$BE
    51:51.553: Start reading frame
    51:51.556: Aldl frame header byte: $A9
    51:51.557: Aldl frame length byte: $5A
    51:51.565: Recv: $A9,$5A,$46,$00,$00,$00,$FF,$B8
    51:51.565: Finished reading frame
    51:51.565: Frame: 10 = $A9,$5A,$46,$00,$00,$00,$FF,$B8
    51:51.565: Start reading frame
    51:51.599: Aldl frame header byte: $90
    51:51.600: Aldl frame length byte: $59
    51:51.607: Recv: $90,$59,$25,$02,$0F,$5D,$84
    51:51.607: Finished reading frame
    51:51.607: Frame: 11 = $90,$59,$25,$02,$0F,$5D,$84
    51:51.607: Start reading frame
    51:51.609: Aldl frame header byte: $91
    51:51.610: Aldl frame length byte: $59
    51:51.616: Recv: $91,$59,$02,$08,$FF,$34,$D9
    51:51.616: Finished reading frame
    51:51.616: Frame: 12 = $91,$59,$02,$08,$FF,$34,$D9
    51:51.616: Start reading frame
    51:51.624: Aldl frame header byte: $20
    51:51.625: Aldl frame length byte: $5C
    51:51.635: Recv: $20,$5C,$9E,$01,$00,$B2,$20,$00,$4C,$C7
    51:51.635: Finished reading frame
    51:51.635: Frame: 13 = $20,$5C,$9E,$01,$00,$B2,$20,$00,$4C,$C7
    51:51.635: Start reading frame
    51:51.649: Aldl frame header byte: $A0
    51:51.651: Aldl frame length byte: $55
    51:51.652: Recv: $A0,$55,$0B
    51:51.652: Finished reading frame
    51:51.652: Frame: 14 = $A0,$55,$0B
    51:51.652: Start reading frame
    51:51.654: Aldl frame header byte: $A1
    51:51.656: Aldl frame length byte: $56
    51:51.658: Recv: $A1,$56,$00,$09
    51:51.658: Finished reading frame
    51:51.658: Frame: 15 = $A1,$56,$00,$09
    51:51.658: Found heartbeat: $A1,$56,$00,$09 - ALDL synchronised
    51:51.658: Send suspend command: $F4,$56,$08,$AE
    51:51.658: Start writing frame
    51:51.658: Send: $F4,$56,$08,$AE
    51:51.659: Finished writing frame
    51:51.659: Start reading frame
    51:51.661: Aldl frame header byte: $F4
    51:51.662: Aldl frame length byte: $56
    51:51.664: Recv: $F4,$56,$08,$AE
    51:51.664: Finished reading frame
    51:51.664: MAX232 echo: $F4,$56,$08,$AE
    51:51.664: Start reading frame
    51:51.667: Aldl frame header byte: $F4
    51:51.668: Aldl frame length byte: $56
    51:51.671: Recv: $F4,$56,$08,$AE
    51:51.671: Finished reading frame
    51:51.671: Start writing frame
    51:51.671: Send: $F4,$57,$0A,$00,$AB
    51:51.672: Finished writing frame
    51:51.672: Start reading frame
    51:51.674: Aldl frame header byte: $F4
    51:51.675: Aldl frame length byte: $57
    51:51.678: Recv: $F4,$57,$0A,$00,$AB
    51:51.678: Finished reading frame
    51:51.678: MAX232 echo: $F4,$57,$0A,$00,$AB
    51:51.678: Start reading frame
    51:51.681: Aldl frame header byte: $F4
    51:51.682: Aldl frame length byte: $56
    51:51.685: Recv: $F4,$56,$0A,$AC
    51:51.685: Finished reading frame
    51:53.319: Resuming normal ALDL communications...
    51:53.319: Send resume command: $F4,$56,$09,$AD
    51:53.319: Start writing frame
    51:53.319: Send: $F4,$56,$09,$AD
    51:53.319: Finished writing frame
    51:53.319: Start reading frame
    51:53.321: Aldl frame header byte: $F4
    51:53.323: Aldl frame length byte: $56
    51:53.325: Recv: $F4,$56,$09,$AD
    51:53.326: Finished reading frame
    51:53.326: MAX232 echo: $F4,$56,$09,$AD
    51:53.326: Start reading frame
    51:53.328: Aldl frame header byte: $F4
    51:53.330: Aldl frame length byte: $56
    51:53.332: Recv: $F4,$56,$09,$AD
    51:53.333: Finished reading frame
    51:53.338: Stop macro: Clear diagnostic trouble codes: CLRDTC
    Any more suggestions?
    TIA.
    Feb 2008
    Any more on this?
    That trace shows the clear DTC macro and it worked perfectly and would have cleared any DTCs.
    You should try logging data now...
    Click on the "Engine data and DTCs (DATADTC)" macro, then click on the green "Start ALDL data".
    You may want to turn off the View->Serial I/O option as that will slow it down.
    Feb 2008
    It works!
    Thanks a ton for the help guys.
    Now I just have to pay for the license to get all the features.
  1. Moates ALDU1+CABL1 ?
    By Ninety8C5 in forum EFILive V4
    Last Post: November 10th, 2009, 04:16 PM
  2. 8192 baud write frame problem?
    By MattStrike in forum EFILive V4
    Last Post: October 20th, 2009, 10:34 AM
  3. 8192 UIN directional stream
    By GMjohn in forum EFILive V4
    Last Post: November 27th, 2007, 08:03 PM
  4. Using 160 baud?
    By Fierobsessed in forum EFILive V4
    Last Post: January 27th, 2007, 11:54 AM
