Some good things are slated for the next (and hopefully final) Black Box Logging beta update.
DMA PIDs can now be logged.
The GM enhanced PIDs are being entered into the config files.
LC-1 and LM-1 wideband serial interface is working (no more analog voltage connection issues - yay!).
PLX and FJO wideband support should follow.
Dyno integration is being added - hopefully that is ready for the next beta release as well. The first phase of this will be just to output various PIDs to a dyno so any dyno controller can log PIDs that it would not normally have access to - like commanded AFR, knock etc. The second phase will be to collect dyno data and log it in FlashScan.
The current schedule is to release the next BB Logging update, on the weekend of 15-16 March.
The screen shot below shows the AFR log from an LC-1 wide band controller. Both digital and analog AFR were captured to provide a comparison. Its a large image, in some browsers you may need to click on the image to show it at the correct resolution.
Blue is lambda,
Yellow is serial/digital AFR,
Green is analog AFR.
