Page 2 of 15 FirstFirst 123412 ... LastLast
Results 11 to 20 of 147
Thread: BB Logging update (March 4th)
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    For those of you wanting to get a jump start on the LC-1, LM-1 serial interface logging, you will need to construct a crossover cable that connects the Innovate serial cable to the FlashScan serial cable.
    See attached image.
    Any Limit to the length on the crossover cable? The serial connecter will not pass through the firewall gromment, I can pass the wires through the gromment, then attach the connector, probably be 2 meters long. Is 2 M OK for the serial port crossover?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Member jay p's Avatar
    Dec 2005
    How about a fix for the 6 speed Allison?
    2019 Sierra 6.2l
    2017 2500HD L5P
    2010 2500HD LMM (sold)
    2005 Harley Ultra Classic
    Feb 2007
    See attached image.
    Theres always one!! What if you are using two LC-1's? Can they be connected at the same time?
    Feb 2007
    Quote Originally Posted by Gelf VXR
    They can be linked in series for the LC-1 software, but will efilive log both?
    Oct 2006
    Oh God that is great , no more Analog inputs for the LC-1 !
    I have one of the JAW's , Just another Wide-band (not assembled yet) , with a Serial out on it as well , wonder if it will work ?
    2006 Trailblazer
    Sep 2003
    See attached image.
    The female 9 pin connector I have has pin 1 where you have the ground connected. From what I found on the web, the male and female pin designations are reversed. i just want to be sure which way to wire the db-9 plug.
    DB9 Male and Female
    DB9: View looking into male connector
    DB9: View looking into female connector
    Oct 2006
    Does it matter which end connects to where , one end for LC-1 and other V2 ?
    2006 Trailblazer
    Quote Originally Posted by Beer99C5
    The cable can be 50 feet long, I think that should be enough
  9. #19
    Quote Originally Posted by jay p
    That's being worked on this Friday. I'm just waiting for the Allison test equipment to arrive. The Allison problem will be solved in this next beta release.
  10. #20
    Yes, EFILive will log multiple* Innovate devices.
    The initial relaese may only support one, but it has been set up to handle mutliple devices and the firmware will eventually support more than one.
    *Limited to four Wide band devices.
  1. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
  2. BB Logging beta update: March 20,2008
    Last Post: March 23rd, 2008, 09:13 AM
  3. March 20, 2008 Update
    Last Post: March 21st, 2008, 07:25 AM
