Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 147
Thread: BB Logging update (March 4th)
  1. #21
    Quote Originally Posted by Ninety8C5
    The female 9 pin connector I have has pin 1 where you have the ground connected. From what I found on the web, the male and female pin designations are reversed. i just want to be sure which way to wire the db-9 plug.
    It was a late night, my bad. The plugs are both MALE, not female. No wonder I had trouble dating when I was at school.
    I'll post new images....
  2. #22
    Quote Originally Posted by tunedbyGM
    Does it matter which end connects to where , one end for LC-1 and other V2 ?
    The crossover cable is symmetrical, it can be connected either way.
  3. #23
    New (corrected) images are posted in the first page of this topic.
  4. #24
    Oh God that is great , no more Analog inputs for the LC-1 !
    I have one of the JAW's , Just another Wide-band (not assembled yet) , with a Serial out on it as well , wonder if it will work ?
    If you have the data format specification that it transmits, let me know and I'll add it as a supported device to FlashScan.
  5. #25
    Paul, cool... good job mate...
  6. #26
    An alternative to fabricating a cross-over cable is to slice up the LC-1 serial cable, swap and solder 2 wires, and apply heat shrink tubing or tape... doing it this way is dirt cheap.
  7. #27
    Oct 2006
    Post some pictures of the Mod !
    2006 Trailblazer
  8. #28
    But then you can't program or log the LC-1 from the PC.
  9. #29
    It may be possible to just order this adapter:
    http://www.bb-elec.com/product_family.asp?familyid=52 Product 9SGM.
    I have just asked B&B if that adapter crosses over pins 2 and 3. I'll post up the reply when I get it.
    If it does cross over pins 2 and 3 then you can use it, if not then back to fabricating your own.
  10. #30
    Oct 2006
    Will see if I can acquire .
    Quote from JAW website :
    "Only Pin 2,3 and 5 are used by JAW."
    Further info when acquired .
    2006 Trailblazer
  1. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
  2. BB Logging beta update: March 20,2008
    Last Post: March 23rd, 2008, 09:13 AM
  3. March 20, 2008 Update
    Last Post: March 21st, 2008, 07:25 AM
