You have to add the wires for the EGR output to be used.So yes they are vacant.Originally Posted by oztracktuning
I got a couple of PCM plugs from a Automotive Dismantler to obtain the wires.
I've had no issues using this method.
856RWHP 408 Supercharged LS1 Holden Commodore.
All the holdens with LS1's i have done, i make up a harness & plug it in to the egr pins on the pcm ,turn on the egr (B1301) load the cal pids and start loging
The auto meter sender looking at the plug is wired
earth pin A .......power 5 volt pin B
............output pin C
Thanks for that info Geoff
Im just waiting on some more pins. But when i checked my pcm harness one of the pins i thought that was for EGR was used. What are the pins again?
Oztrack
EFILive Tuning Consultant
Worldwide Remote Tuning Service
2006 NSW Super Street Drag Racing Champion
www.oztrack.com.au
Here is the link:Originally Posted by oztracktuning
http://download2.efilive.com/Tutoria...20Tutorial.pdf
It works great. It saves buying another gauge.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System;
Tinted Windows 35%;EFILive Tune
I just logged mine at the track with 155 dry shot of Nitrous. The FP went down slowly as rpms build to as low as 39psi , it drops smoothly under any load. My car would have a bit over 600rwhp with a shot that size.
Oztrack
www.oztrack.com.au
I just picked up the 2246 sensor and a TPS sensor pigtail and was wondering if I have the pins labeled correctly for the sensor in the below pic. Thanks
yes that,s right
Cool, thanks.
thanks for the write up...
my efilive v1 should arrive today and I have this mod installed and ready to log...
