Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Wideband serial update
    Default Wideband serial update
    A couple of screenshots of the wideband serial interface for FlashScan:
    Press F1 to toggle display between Lambda and EQ Ratio.
    Press F2 to toggle display between two separate controllers. (Note that a second LC-1 was not connected so "Controller Not Found" is displayed for controller #2).
    Press O to to perform a free-air calibration on an LC-1.
    I expect to release the beta firmware tomorrow night.
    It will include the BB Logging update as well.
ID:	2839   Click image for larger version.
ID:	2840   Click image for larger version.
ID:	2841   Click image for larger version.
    Will this be a full install for the beta or do I need to install the current beta and then this update?
    Al
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    Will this first beta be for only LC-1, or will the other controllers that have been talked about like my Tech Edge be supported as well?
    Oct 2006
    For those of us who have a Innovate Product , this is like Christmas in March .
    2006 Trailblazer
    Jul 2003
    /bow
    but this will also work for an LM1 right?
    Jan 2005
    It's always Christmas here!
    Paul - Your V2 is nude! We normally ban folks for posting nudy pics on the forum, but, since you're the man and all, I think we can let it slide just once.
    Quote Originally Posted by ChipsByAl
    Al
    It will most likely be a full install.
    Quote Originally Posted by kbracing96
    The following controllers are supported now:
    LC-1 (up to 2 LC-1s may be connected)
    LM-1 (up to 1 LC-1 and 1 LM-1 may be connected)
    PLX SM-AFR (up to 2 PLX's may be connected)
    TechEdge 1.5
    TechEdge 2.0
    JAW
    AEM UEGO
    And, still waiting to hear back from FJO regarding their serial data format.
    Note: Only the LC-1 has been comprehensively tested, the others have all been developed from their respective manufacturers' data sheets. So there may be some initial teething problems with reading the serial data.
    Quote Originally Posted by Highlander
    /bow
    Yes, but see note in previous post about teething problems.
  1. Serial Wideband AFR & B3601
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2010, 05:51 AM
  2. log serial wideband
    By b18cls1 in forum Black Box Logging
    Last Post: February 12th, 2010, 04:46 AM
  3. Can't log serial wideband anymore
    By white01ss in forum Tutorials
    Last Post: October 28th, 2009, 09:39 AM
  4. serial wideband
    By articSS in forum Black Box Logging
    Last Post: December 19th, 2008, 07:04 AM
  5. Serial wideband.....CAN or RS232?
    By Redline Motorsports in forum FlashScan V2
    Last Post: September 10th, 2008, 03:00 AM
