Results 1 to 10 of 16
Thread: no controller found
    Nov 2006
    Default no controller found
    i in stalled the current BBL update and i have
    not been able to see WBO2 data.
    everything seems to be installed properly.(bootblock,firmware,ect)
    i have configured the scan options to connect with flashscan V2.5(hapi),
    dragged the config. files to the config tab,
    and added the new external WBO2 pids to my pid file.
    i then dragged my pid file to the scan tab through efilive explorer.
    i select properties of the pid file and
    it says it has not been implemented yet.
    i have also selected the WBO2 type though the V2 it self with options setup.
    everything else is working properly, my RR updates but
    with BEN from analog input.
    should the V2 automatically detect and record the LC1 data
    or do i need to change/select something to connect to the LC1?
    thanks
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    You need to go into the EFILive module's settings menu.
    Options -> Setup -> Edit Settings
    Scroll down to the COM In and COM Out and change those to Wide-02. Change the W02 Type to Innovate.
    Give that a try.
    Nov 2006
    Quote Originally Posted by mr.prick
    thanks
    i have done that, to no avail.
    my pid file is installed on the scan tab(efilive explorer)
    so i assume that the pid file is uploaded to the V2,
    yet i get no pids selected from the display data option as well.
    Make sure you are not using any of the old *.pmm files form the previous beta release. Only use the new *.pmm files that were included in the March 20th update.
    Other than that I can't see anything that would cause the problem you are seeing.
    After the logging fails, Select the Scan Tool->Scan Options->Sace Trace File. Then copy the saved trace file and send it to me at paul@efilive.com.
    Include a link to this thread so I can correlate the trace file with this thread. Also please send the Options.ini file and the model-year of the vehicle being logged.
    Nov 2006
    i re-downloaded the zip file and re-extracted the folder
    in case i had a bad download,re-formatted the V2,
    then loaded the .pmm files.
    should only .pmm files be uploaded to the V2?
    i have 2 .ini files in the config folder that are uploaded.
    it displays data just no WBO2 data.
    i`m going to get another gender bender to connect my cables,
    maybe that is the problem.
    What wide band controller are you using?
    Can you log the serial port using a serial port monitor as described in the first post of this thread:
    http://forum.efilive.com/showthread.php?t=7566
    (See point 4).
    Nov 2006
    the free serial port monitor shows the port
    but the free version can`t record so i can`t post a log.
    i can connect the LC1 to my laptop with
    my serial to usb bridge with no problem.
    i`m pretty sure it is the gender adapter,
    for everything else is working properly.(scan+tune+roadrunner)
    it is easter sunday and i was unable to find a new adapter
    or a cable that could link the V2 and LC1 together.
    Senior Member Wasted Income's Avatar
    Dec 2005
    Any luck on finding an adapter that works? I'm having the exact same problem with my LC-1. I know the port is working, because I was able to program my LC-1, but it is showing up ass "Controller Not Found" when I connect it with the serial connection. I think my problem is also my gender bender.
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Can you post a screen shot of what it captures?
  1. WB not found
    By driver456 in forum FlashScan V2
    Last Post: May 30th, 2010, 03:59 PM
  2. GMPP Gen-IV controller kit
    By PSWired in forum Gen IV V8 Specific
    Last Post: April 18th, 2008, 01:50 PM
  3. WBO2 controller
    By Thumper in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2008, 12:53 PM
  4. V2 controller
    By twinki025 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 05:27 PM
  5. Bosch ECM controller i.d.
    By forcefedjunkie in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 11th, 2007, 08:47 AM
