Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 104
Thread: BB Logging beta update: March 26, 2008
    Quote Originally Posted by swingtan
    I just tried a quick E38 BBL session and I still cannot log any DMA PID's. the options file has the following defined....
    ECM, ECT, -40:110:1:1:0
    ECM, IAT
    ECM, MAP
    ECM, E38.APCYL_DMA
    ECM, RPM, 0:6500:2:1:0
    ECM, SPARKADV
    ECM, ETCTP
    ECM, VSS
    ECM, E38.AFRATIO_DMA
    ECM, KR, -1:1:34:5:0
    ECM, E38.OCTSCL_DMA
    But none of the "DMA" pids appear in the log file. I'll try a long-ish log tonight to see if the lock up problem is fixed.
    Simon
    Probably my fault , I just realized we renamed the *_DMA PIDs to *_M. It may be you need to rename them in the Options.ini file as well.
    I will try that here as well to see if that is the problem.
    P.S. Check the PID names in the PID description files. The DMA PIDs are named *_M only.
    Quote Originally Posted by Redline Motorsports
    Paul,
    I have been hesitant to download this update as our tuning workload is jambed. Can't afford to have a non functioning V2. Should we hold off or is it a fairly stable update.
    Howard
    It is a lot more stable than the early releases, I recommend holding off until we figure out the last few niggly problems. Should be about 2 weeks.
    Jul 2007
    I did........
    Extracted the zip file and over wrote all existing files.
    Formated the config directory and copied all files across to the config directory.
    Updated the firmware to 0326
    Still no E38 DMA PID's
    , too fast for me Paul... I'll check thos PID names right now....
    Sep 2003
    Strange, I just tested it again here and it works fine. Did you upgrade the firmware to release: (0326)? Did you copy the new *.pmm files to FlashScan?
    You are right, it does work. In my haste to try the new update, I copied the new config files to Flashscan, but forgot to update the firmware.
    Sep 2003
    DMA PIDS still don't seem to work. I tried both '-, DYNCYLAIR_M' and 'PCM, DYNCYLAIR_M' separately, but neither worked.
    Jul 2007
    Good news on the E-38 front!
    I replaced all _DMA with _M and dropped the "E38." from the front and they work like a charm! As soon as I read your post Paul I thought, I've read that somewhere before, but had forgotten all about it.
    Now, how do I see them in the Scan tool as it still seems to be looking for _DMA PID's ?
    Simon
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Just curious, what do I need to do to pass through the LC-1 data to the laptop? I had previously used the external analog inputs. Do I need to update something in the sae.generic.txt file?
    This part?
    # Innovate LC-1 WBO2
    *CLC-00-932
    V 0.0 5.0 .1 "{EXT.AD1}"
    AFR 10.0 20.0 .2 "({EXT.AD1}*3)+7.35"
    *CLC-00-933
    factor 0.0 2.0 .1 "{CALC.AFR_LC11.AFR}/{GM.AFR}"
    Sep 2003
    I've noticed in the last two updates that in the Scan Tool when you go to 'Enter VIN' and want to enter the 'Op system' only a few of the operating system show up when you click the 'down arrow'. I can type in 19980400 but before this all the operating systems were on the list.
  9. #19
    Quote Originally Posted by Ninety8C5
    My Bad :(
    The 97/98 controllers do not report a valid operating system number. The DMA PID's memory addresses are indexed based on operating system number. FlashSCan is not able to correctly identify which DMA PIDs are valid for 97/98's. In the PC based scan tool it uses the VIN to generate pseudo operating system numbers. I have not put that ability into the FlashScan device. Doing it now...
    When testing this I also realized that there are no DMA PIDs defined for LS1s or LS2s in the Options.ini file. I mistakenly thought there was and that they were being successfully tested. :(
  10. #20
    Quote Originally Posted by Kevin Doe
    This part?
    *CLC-00-932
    *CLC-00-933
    I recommend adding new calc PIDs to the calc_PIDs.txt file in \My Documents\EFILive\V7.5\User configuration.
    Here's one I prepared earlier:
    Code:
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter  Value            Description
    VERSION     7.1.1            File version
    DECSEP      .                Decimal separator used in this file
    # Units
    *UNITS
    #Code     System     Abbr     Description
    None      None       ""       "No units"
    # Add slot definitions here
    #Units             Low          High      Fmt  Expression
    # ALL Wideband serial controllers
    *CLC-00-101
    factor             0.0           2.0       .1  "{EXT.WO2AFR1}/{GM.AFR}"
    *CLC-00-102
    factor             0.0           2.0       .1  "{EXT.WO2AFR2}/{GM.AFR}"
    #Code                      PRN  SLOT         Units            System           Description
    CALC.BEN1                  F000 CLC-00-101   factor           O2-Wide          "Base Efficiency Numerator Bank 1"
    CALC.BEN2                  F001 CLC-00-102   factor           O2-Wide          "Base Efficiency Numerator Bank 2"
  1. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  3. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  4. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  5. BB Logging beta update: March 20,2008
    Last Post: March 23rd, 2008, 09:13 AM
