Results 1 to 9 of 9
Thread: TTi Stage 1 Question/DIY Tuning
    Jul 2005
    Default TTi Stage 1 Question/DIY Tuning
    Do you guys who work on your own tunes:
    (preliminary mod info: TTi Stage 1, Ramdom Tech High Flow Cats, large single BOV one of only a few, running a quart of Torco per tank to eliminate a couple degrees KR)
    1. Turn off the after CAT O2 sensors?
    2. With the after CAT 02 sensors turned off, would this be considered 'open loop' or will the pre-CAT O2 sensors make it 'closed loop'? (curiosity question)
    3. What AFR do you try to achieve for your street tune?
    4. How lean do you tune for race events?
    5. With my setup, would going to AutoTune, MAFless SpeedDensity, and a WB O2 sensor be worth the effort/expense? (note: not really looking to go over 500RWHP/RWTQ, if I can get there with this setup)
    Thanks in advance for the response(s),
    Lonnie
    __________________
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Stingers Quad Oval/no Cats, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Jul 2005
    ttt
    Is there some reason that I am not getting a response to this question?
    Wrong Forum?
    Too many questions?
    Too complex?
    No one knows the answers?
    Other more important questions to answer?
    Thanks in advance for any/all help.
    Lonnie
    2002 EB Coupe, MN6
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Re: TTi Stage 1 Question/DIY Tuning
    Yep or Simms
    Can still be closed Loop or Open depending on what you want
    Cruise 14.7 WOT 12.8
    12.8
    Yes and Yes
    Quote Originally Posted by lplott
    Closed loop uses the pre-cat O2S's; you can opt to run closed loop or open loop in the .tun.
    The after-cat O2S's are for testing the cats' operation.
    Oct 2003
    What is a
    TTi Stage 1
    ? Twin Turbo setup? Stage 1??
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Quote Originally Posted by bink
    What is a
    TTi Stage 1
    I want a Turbo if it did not cost soooo much!!!!
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Jul 2005
    BowlingSS
    What is a TTi Stage 1:
    Turbo Technologies Inc
    Twin Turbo Stage 1
    GT25 turbos
    8psi
    twin intercoolers
    twin K&N air cleaners
    single large adjustable Blow Off Valve
    stock MAF
    approx 480rwtq/466rwhp
    Lonnie
    2002 EB Coupe, MN6
    Nov 2003
    Thanks. What HP/TQ increases did you see?
    Bill
    Jul 2005
    Without the sheets in front of me, I seem to remember numbers like:
    160 +- rwhp gain
    180 +- rwtq gain
    If you want it more exact I would have to dig up the dyno sheets from the install...
    From what Mike at Xtreme has told me, my kit makes a little more power than most TTi Stage 1 kits they have installed so these numbers might be a little off.
    Lonnie
    2002 EB Coupe, MN6
  1. Stage 3 timing table
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: November 14th, 2008, 05:09 PM
  2. Two Stage Nitrous Dry/Wet
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 9th, 2008, 03:30 PM
  3. 2 stage rev limiter
    By hymey in forum E37, E38 & E67 PFI ECM's
    Last Post: February 6th, 2008, 12:29 AM
  4. Need tune for Hotcam, Headers, Stage 3 heads!!!
    Last Post: October 13th, 2005, 05:09 PM
  5. Tuning without o2s question
    By tuff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2005, 03:12 PM
