Okay, So I've changed my intake on my '96 from running the crappy L31 poppets, to a MPFI intake running some common EV1 style Injectors like these:
I'm using a 411 PCM running COS 3 based off OS#12212156 for a 2002 express van. well, I've got it running and doing well, but I KNOW some of the injector tables like B4005 are off quite a bit from the poppets (the poppet injector B4005 stock table is almost ALL negative ), but I'm having a hard time trying to find another tune that runs this type of injector running the same OS so I can get the #'s from.
I know the C3500 on holdencrazy uses the same injectors, but the OS is way different and much of the injector tables don't transfer over.
Does ANYONE have a stock tune for anything running OS#12212156 and those EV1 injectors?
