Results 1 to 9 of 9
Thread: DSP5 Problem?
    Default DSP5 Problem?
    I've noticed that when I'm running the DSP5 OS, I often get about half a second of "dead pedal" when I take off from a dead stop. Never noticed it with stock or DSP2. Anyone else noticed this?
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Quote Originally Posted by Cougar281
    Does it happen on all DSP5 settings
    Quote Originally Posted by vortecfcar
    Seems to... But not 100% of the time.
    It sound's like you missed something in your tables because mine work's fine.
    Haven't had a support Email about that yet.
    EFILive Distributor Site Admin Trippin's Avatar
    May 2004
    Which stock and modified OS?
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Guy, its an 04 OS (15141668) and 04166805 DSP5 OS. I JUST created a new one from scratch like two weeks ago that's doing the same thing as the one I originally posted about. Any suggestions what I should log to try to see what's going on?
    Junior Member LarryJewell's Avatar
    Jan 2007
    I have the same operating system with zero issues
    2004 Duramax LLY, 71.5mm Cheetah turbo, Mike L, Transmission, EFI Live
    I know this is late, but I had the same issue back in say March of 2007. I remember this paticularly. I'd give it fuel and it did nothing for a second or two and then picked up. I actually thought there was a thread and fix for it over on dp back then.?? Mine's fine now though.
    and it was a different OS
    2005 Duramax LLY with LOTS of goodies
  1. new to efi and dsp5
    By 516rider in forum Duramax LLY
    Last Post: January 26th, 2010, 12:24 PM
  2. Dsp5 lly help!
    By josh08 in forum Duramax LLY
    Last Post: December 6th, 2009, 02:33 PM
  3. dsp5 problem
    By brandon04lb7 in forum Duramax LB7
    Last Post: January 9th, 2009, 01:50 AM
  4. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
