Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: 2000 to 2002 cos5 auto VE problem
  1. #31
    Oct 2007
    your done, set the commanded fuel open loop tabel to 14.63 and the the fuel trims work...
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
  2. #32
    Senior Member RandyWS6's Avatar
    Jan 2005
    I logged one more time after posting, Now this is what happening, Strange!!!!
    The first one the Main VE table started out around 1.07 and averaged out around 1.01 to .98
    The top pic is after copy & past ,but after copy & past, it made the second pic go rich
    one goes good them after pasting it goes rich ,back and forth, can not get it to do the same two logs twice in a row
    On the last log ( second pic.) it started out rich .90s and leveled out some what fair.
    This pic here is the one you say I'm ready ,looks grate
    #14 log is loaded in 0002 tune
    #16 log is loaded in 0003 tune
    This pic here is the last one i done ,nothing change in the tune but it went rich for some reason ,But i can install ether one .
    2000 WS6 TransAm-M6 LS3 forged 422 cid. 4L80 FMVB ,4:22 Ford 9"-35 spline axles
    2014 C7 3LT-Z51 Corvette Stingray M7 , A&A Supercharger , Kooks 1-7/8" long tubes & X Pipe 615 rwhp & 560 rwtq
    http://community.webshots.com/album/259987907DcztOG
  3. #33
    Jan 2005
    I'm not able to view your logs right now, but I would speculate changes in the ambient temps are providing a bit of the tail chasing you are seeing. This is where the IAT VE scalar comes into play.
  4. #34
    Jan 2005
    On your other question, yes, it's normal to see your average values change as you collect more data for each cell. Typically the extreme high and low values you see are due to transient conditions.
    While you are logging your data, it's very important that you control your right foot to avoid causing excessive transients.
  5. #35
    Jan 2005
    Well i believe Ive got it all done ,can you look at my log and see what you think, The only thing I'm have trouble with now is I'm having a miss or stumble in the upper rpm range around 6400 to 6600 rpms. I have a wot run at (frame 8439)
  6. #36
    A0011 and A0012 are out of range... set them to 511.
    WOT is good.
    PT is not as close... STFT's average about -9% during PT, but that's ok, you're letting the STFT's do the trimming.
    Good job.
  7. #37
    You may also want to log the following:
    - DYNAIR (gives an idea of airflow rate),
    - DYNCYLAIR_DMA (used to index into HO/LO spark tables),
  8. #38
    Jan 2005
    do you meen A0012 & A0013 ,the A0011 is valet mode or two step it wont let me put numbers in there
  9. #39
    Jan 2005
    I dont have the pin56 installed yet for the valet mode
  10. #40
    Oct 2007
    now ur tuning randy...
  1. upgrade from 2000 o.s to 2002.os
    By smslyguy in forum Vortec V6/V8 Specific
    Last Post: August 31st, 2009, 06:18 AM
  2. Anyone done a Corvette 2000 OS to 2002 OS change?
    By aleco99 in forum Gen III V8 Specific
    Last Post: September 24th, 2007, 01:24 AM
  3. Does any body have a OS 2000 to 2002
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: August 21st, 2007, 08:40 AM
  4. Going from 2000 to 2002 OS problem ?
    Last Post: June 9th, 2007, 10:00 AM
  5. ? ON CUSTOM O.S. & 2000-2002 FLASH
    Last Post: September 6th, 2005, 02:30 PM
