Joe (Moderator)
A wideband is relatively cheap and does show you what is actually happening.
Joe (Moderator)
Actually you can dial in VE and MAF tables [separately] in CL using LTFT's.
WOT may be tricky because at WOT positive trims are held but negative trims are zeroed.
is there a combatable WB with EFILive
Joe (Moderator)
EFILive already supports the various most popular widebands...
For any wideband not supported, EFILive allows you to create a calculated pid for it...
you just have to know two voltage:AFR points if it's linear, or enough voltage:AFR points to specify a lookup table.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
