Code:
; _______________________________________________________________________
; | Copyright © 1999-2007 |
; | EFILive Limited |
; | web: http://www.efilive.com |
; | email: [email protected] |
; |_______________________________________________________________________|
; Modifications
; _________________________________________________________________________
; Version | When | Who | Why
; 8.0 | 2007-Feb-16 | PSB | Created file
*VEHICLES
;Vehicle selection list
; Cap1 and Cap2 form the "on-screen" display option from which the user may select.
; Controllers lists 1 or 2 "&" seperated pid memory map (*.pmm) files.
; PSL is the PID Selection defined later in this file
; PCU is the PID Custom Units defined later in this file
;Cap1 Cap2 Controllers (Engine&Trans) PSL PCU
A->, O2S, LS1B_A.pmm, PSL_A, PCU
B->, LTFT, LS1B_A.pmm, PSL_B, PCU
C->, TRANS, LS1B_A.pmm, PSL_C, PCU
D->, LOOP, LS1B_A.pmm, PSL_D, PCU
; PID Selection List
; Node: Is one of PCM, ECM or TCM (use "-" for external PIDs).
; PIDs: Is one or more "|" seperated PID names. The first valid PID will be used.
; Alarm: Is 5 ":" seperated fields:
; min: Minimum value, below which the alarm will sound.
; max: Maximum value, above which the alarm will sound.
; style: Is one of:
; 0 = No sound, No LEDs
; 1 = Low pitch
; 2 = Medium Pitch
; 3 = High Pitch
; 4 = Very high Pitch
; 16 = Illuminate LED 1
; 32 = Illuminate LED 2
; 48 = Illuminate LED 3
; 64 = Illuminate LED 4
; 128 = Illuminate LED 5
; Add Pitch and LED values together to enable audio and visual alarms.
; For example, for Medium Pitch and LED 4, use 2+64 = 66
; time: Time (in 10ms increments) for which alarm will be sounded.
; hold: Time (in seconds) for which the displayed value will be frozen (not implemented yet).
*PSL_A
;Node PIDs (pid1|pid2|...|pidn) Alarm (min:max:style:time*10ms:hold*sec)
PCM, TP
PCM, DYNCYLAIR_M
PCM, MAF
PCM, DYNAIR
PCM, GEAR
PCM, ECT, -40:110:97:1:0
PCM, RPM
PCM, EQIVRATIO
PCM, HO2S11
PCM, HO2S12
PCM, HO2S21
PCM, HO2S22
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, KR, 0:2:147:1:0
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_B
PCM, TP
PCM, MAF
PCM, GEAR
PCM, RPM
PCM, EQIVRATIO
PCM, HO2S11
PCM, HO2S21
PCM, SPARKADV
PCM, IBPW1
PCM, IBPW2
PCM, IAT
PCM, MAP
PCM, LONGFT1
PCM, LONGFT2
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_C
PCM, TP
PCM, DYNCYLAIR_M
PCM, MAF
PCM, GEAR
PCM, RPM
PCM, EQIVRATIO
PCM, HO2S11
PCM, HO2S21
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, SHIFTLAST
PCM, LONGFT1
PCM, LONGFT2
PCM, TFMPRS
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_D
PCM, TP
PCM, MAF
PCM, GEAR
PCM, RPM
PCM, EQIVRATIO
PCM, FTC
PCM, FUELSYS
PCM, HO2S11
PCM, HO2S21
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, LONGFT1
PCM, LONGFT2
PCM, TFMPRS
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
; PID Custom Units
; PCU specifies the controller and PID for which to define a custom unit
; Caption is the caption displayed on screen during BB logging (8 characters maximum).
; Prec is the number of decimal places to display
; Units is the display units name.
; Op is the operator, one of:
; * = multiply
; / = divide
; i = invert_then_multiply
; The metric value of the PID is multiplied, divided or inverted then multiplied by Factor.
; Offset is then added.
*PCU
; PID Caption Prec Units Op Factor Offset
PCM,MAF, AirFlow, 1, lb/m, /, 7.559873,
PCM,MAP, Manifold, 1, psi, /, 6.894757,
PCM,TFMPRS, Trans, 1, psi, /, 6.894757
PCM,VSS, Speed, 0, MPH, /, 1.609344,
PCM,EQIVRATIO, AFR, 3, AFR, i, 14.63,
PCM,ECT, Coolant, 0, °F, *, 1.8, 32.0
PCM,IAT, Intake, 0, °F, *, 1.8, 32.0
-, T1, T1, 0, °F, *, 1.8, 32.0
-, T2, T2, 0, °F, *, 1.8, 32.0
