Results 1 to 10 of 17
Thread: STFT Main VE dialling etc....
    Jan 2007
    Default STFT Main VE dialling etc....
    Here's the tune and log from the run home.
    This shows the NBO2 voltages.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Interesting...
    HO2S1x voltages are shifted down a little (lean), confirmed by wideband AFR (ignore where I put the cursor).
    Jan 2007
    Please elaborate Joe????
    Howard
    DUCT TAPE.
    Oh, I was observing that your HO2S1x voltages swing between 0mV and 750mV... (i.e. the centre voltage would be 375mV rather than 450-500mV) which indicates a lean tendancy, and your WB says about 17 AFR...
    they correlate with each other.
    Hmmm... the STFT's are trimming to this...!!!
    Jan 2007
    Ahh....OK.
    So...any idea how this would happen?
    Howard
    DUCT TAPE.
    Jan 2007
    looking at the data it's between 0 and 960???
    Howard
    DUCT TAPE.
    Oct 2006
    Joe, the average voltage is around 520mv which correlates roughly with his switchpoints in the tune. Is this the wrong way to look at the voltages? I would of thought with the equal times spent over & under the switchpoint an average value would be a fair indication.
    Howard,
    I had to break off last night, I do apologize...
    5.7ute, you're right, the average is ok, I was not looking at it right, please disregard my comment about HO2S1x voltages.
    But...
    look at the wideband AFR, it shows about 17 AFR...
    a look in the tune shows B3647 to be EQ 1.00 and B3601 to be 14.63...
    the log shows the STFT's are trimming to this, but the wideband says 17.
    I expected the wideband AFR to be hugging the commanded AFR...!!!
    Jan 2007
    Damn Joe...what? You've got a life outside of this forum and tuning cars?
    Where did you get that? Gotta put that on my list as the next mod I buy. Lol!
    I used to have the commanded and actual AFR pretty close...so I don't know what's happened.
    Howard
    DUCT TAPE.
    My Mrs was yelling at me to eat or sleep or something......I think that's her job...
  1. stft (your input)
    By drdarthinvader in forum Custom Operating Systems
    Last Post: April 23rd, 2010, 10:49 PM
  2. STFT Idle
    By Mort in forum Custom Operating Systems
    Last Post: October 17th, 2009, 02:46 AM
  3. stft problem
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 12:22 AM
  4. Looking for STFT & other pids
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 21st, 2008, 10:21 AM
  5. stft
    Last Post: April 8th, 2008, 02:39 PM
