why doesn`t the V2 control panel work any more?
it was easier to calibrate the AD inputs when you
could see the voltage through the software.
now the only way to do it is through the V2 itself and
that seems to be a bit difficult when you cant see
the voltage in real time.
before the control panel was animated.
this is just a general complaint with the software not a bug.
also while i`m complaining, it would be nice to scan though
the V2 and the software at the same time.
Did you change the connection (cable type) in the Scan Tool to be the V2.5 FlashScan interface? Perhaps also disable the cable auto detection.
Andrew
EFILive Crew
For me everything worked out rather smooth, but while BB logging my LLY the PID GM.TP is not logged even though it is included in the options.ini
I also had to remove the Allison PIDs from the options.ini for the V2 to start logging frames. Before it was just toggeling between 0 for all values and the actual value without increasing the frame counter.
This might have been caused by the large number of PIDs I log.
2005 RCSB 2500HD GMC Sierra DURAMAX LLY
1955 Chevy Truck 1st series, being restored
2002 Mercedes C270 CDI
I have fixed a number of connection/detection issues in the latest update. Hopefully I can release it by Sunday night.
Please try again with the new software to see if those problems are resolved.
