Results 1 to 10 of 12
Thread: Error code $0109 after update
    Jun 2007
    Default Error code $0109 after update
    I updated my bootblock and firmware but I get error $0109 when trying to format config files or trying to do anything in efilive explorer. How can I fix this? I really want to log using my widebands serial out.
    Are you also running the latest EFILive_Explorer and EFILive_Hapi software?
    The versions that are compatible are:
    EFILive_Explorer.exe should be version 8.1.1.21
    EFILive_Hapi.exe should be version 8.1.1.21
    You can check the version of executable files by right clicking on them in Windows Explorer and selecting Properties.
    The boot block and firmware should be:
    FSBootV2_05_06(0407).efw
    FSProgV2_05_16(0407).efw
    Jun 2007
    Thanks, I'll check that. Right now my V2 won't go past the slash screen and the blue and amber LEDs stay on when I connect it to my car.
    Quote Originally Posted by Big Block View Post
    What happens if you disconnect for at least 5 seconds, then reconnect while holding down the Ctrl key on FlashScan's keypad.
    Does it go into dead poll mode where the two orange LEDs are flashing?
    If so, do that while connecting to the PC and then (on the [Firmware] tab page of the EFILive_Explorer program) check your bootblock is V2.5.06 and your firmware is V2.05.16
    Alternatively, if you can get it to boot past the splash screen (try Ctrl+Cancel) check the version numbers via this menu sequence: F4->F2->F1, then scroll down to the version numbers.
    Jun 2007
    Yes, it goes into dead poll mode. It says I have bootblock 2.05.04 and firmware 2.05.16 Guess I should try and load the correct bootblock.
    Jun 2007
    When I try to run the latest version of explorer I get error $0025 popping up multiple times untill I terminate the app.
    Jun 2007
    When I try to change the bootblock it says bootblock installed but then I check it and it is still 2.5.04.
    How can I get this to work?
    I would try re-booting windows. Error $0025 is "Can't get semaphore for control of EFILive_Hapi". That indicates that some residual process is still holding on to the semaphore that EFILive_Explorer wants. I could spend a few hours trying to diagnose why, but rebooting should be the quickest way to clear that. If that still does not fix it, let me know.
    When I try to change the bootblock it says boot block installed but then I check it and it is still 2.5.04.
    If you've got boot block V2.05.04 and firmware 2.05.16, then it looks like you've tried to update the firmware before updating the boot block.
    You MUST update the boot block first, then the firmware, i.e. in this order:
    1. Update firmware to V2.4.70 (you've already got that far).
    2. Update the boot block to V2.05.04 (you've already got that far).
    3. Update the firmware to V2.05.15(0326) - not sure if you've done that.
    4. Update the boot block to V2.05.06
    5. Update the firmware to V2.05.16(0407)
    You should be able to flash the V2.05.15(0326) firmware back into the FlashScan unit using EFILive_Explorer (assuming the $0025 error is resolved).
    Once you've done that, start again at step 4 above.
    Jun 2007
    When I first open explorer with FS V2 in dead poll I get a dialog box that says error $0109. I flash the firmware V2.05.15(0326) . Then after the v2 reboots I close explorer and reconect the v2 in dead poll. I then open explorer and flash boot block to V2.05.06 a dialog box comes up that says bootblock flash completed or somethin like that and it also says flash latest firmware, but when I refresh the firmware in the EFILive Control panel it says that I still have boot block V2.05.04 ....??
  1. Error code
    By Toired Old Man in forum FlashScan V2
    Last Post: October 24th, 2008, 09:17 AM
  2. error code 11?
    By dynarex in forum General (Diesel)
    Last Post: April 23rd, 2007, 10:07 AM
  3. Error code: ERR_NOCABLE/31
    By Chalky in forum General
    Last Post: May 16th, 2006, 09:40 AM
  4. error code ERRNOINIT/121
    By raptor in forum EFILive V6
    Last Post: November 14th, 2005, 08:51 PM
