Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Rich Idle - Please Help!
    Jan 2008
    Default Rich Idle - Please Help!
    Just started tuning in Jan 08 so please bear with me...
    The problem is that the car is rich at idle and a lean when cruising. It's got a S/C on it with SVO/Bosch green top 42lb injectors and a Racetronix fuel pump. Stock MAF w/screen.
    What I've tried so far:
    1) B4001 The IFR table is dialed in according to the injectors.xls
    2) B3701 The Inj Pulse Width Voltage Adj table is dialed in. Got specs from Ford to adjust this table. The car was VERY lean in the 35kpa and up columns before bumping up that table. Tried pulling down the 30 kpa and under rows and it didn't make much of a difference.
    3) B0101 Been tweaking on the VE table based on LTFTs and it's made a lot of difference in the 35kpa and up trims, but almost no difference in the 30kpa and lower under 2000 RPMs.
    I noticed that my Injector Pulse Widths at idle have had a range of 1.892 to 2.107 ms. I can't seem to get the PCM to command a pulse width shorter than 1.892 ms even when the injector can do 1.13 ms!
    I know, I know. I need a wide-band and do the AutoVE. I'm getting one in a month or so, but the car's inspection is out so I need a quick fix just so I can get it inspected. Right now, you can just smell the fuel when it's warmed up and idling. Any one have any ideas?
    Thanks,
    Dan
    2001 Camaro SS
    Built 370 LQ9, Ported 243s, D-1SC 14 psi. 691 rwhp, 643 rwtq
    Best time: 11.6@124 on nitto drags with a 2.1 60'
    "if you're gonna build a time machine into a car, why not do it with some style." Dr. Emmett Brown
    Jan 2008
    Default Previous log and tune...
    Here's a version before where I raised the B4307 Desired Airflow 5%. This was to help the lean upper RPM cruise problem. B4308 Airflow Parked is also a little lower.
    2001 Camaro SS
    Jan 2008
    bump for my stinky car
    Jan 2007
    Hi Dan,
    how did you come up with the IFR's in your tune?
    I used the attached sheet (after searching for MANY hours on the net) and used 43.5 as the standard pressure for calc'ing the new IFR. I know alot of people say Ford use a diff pressure for calc static flow...but Marcin (REDHARDSUPRA) had 2 sets tested and at 43.5 they flowed close enough to 42 to call it OK.
    This would mean your IFR table should look like:
    6.110675
    6.148759
    6.186608
    6.224227
    6.261620
    6.298791
    6.335744
    6.372483
    6.409011
    6.445332
    6.481449
    6.517367
    6.553087
    6.588614
    6.623950
    6.659099
    6.694063
    Also...how did you come up with the B3701 table and the others?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Howard,
    In the IFR calculator, I believe the 0-80 column should be labeled
    MANVAC(kPa).
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Jan 2007
    Thanks Joe...I don't think I can change it..I found it somewhere online.
    Howard
    DUCT TAPE.
    Howard,
    It wasn't locked, so I changed it.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Jan 2007
    Cool..thanks Joe.
    Howard
    Howard
    DUCT TAPE.
    Jan 2007
    Here's another injector sheet.
    But...how do I use it?
    Howard
    DUCT TAPE.
    Jan 2008
    Quote Originally Posted by hquick View Post
    Hi Dan,
    Howard,
    I used the following numbers. I have a Racetronix pump and the pressure is a little higher than stock.
    Injector Rated Fuel Pressure: 39.5
    Your Fuel Rail Pressure: 62.5
    Injector Rated Flow Rate: 42
    Injector Flow Rate (Grams/Second)
    Manifold Vacuum kPa {link: GM.MANVAC}, Value
    0 6.656250
    5 6.695313
    10 6.734375
    15 6.773438
    20 6.812500
    25 6.851563
    30 6.890625
    35 6.929688
    40 6.960938
    45 7.000000
    50 7.039063
    55 7.078125
    60 7.109375
    65 7.148438
    70 7.187500
    75 7.218750
    80 7.257813
    Also, the car was already running rich, so I didn't want to make the problem worse by lowering the IFR.
    2001 Camaro SS
  1. help! rich at idle
    By drdarthinvader in forum Custom Operating Systems
    Last Post: December 13th, 2008, 07:00 PM
  2. New cam - rich idle??
    By Tomcat in forum Gen III V8 Specific
    Last Post: May 13th, 2008, 08:38 AM
  3. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 04:17 PM
  4. Idle is rich
    By zapp168 in forum Gen III V8 Specific
    Last Post: August 14th, 2007, 10:29 AM
  5. Rich idle
    By gcross in forum Gen III V8 Specific
    Last Post: January 10th, 2007, 02:35 AM
